Distrb wrote:i would go with what the LSD manufacturer reccomends, which is for TRD 75w90. Obviously they're going to reccomend their own oil, but Castrol Syntrax is made in that weight and works well.
Is what i use in mine, with the same type of LSD
dotdog wrote:I would never run mulitrax again in a c52 with a trd lsd, I did for about two weeks and it make the diff run like a locker. I put the recomened trd oil in it and now its smooth as anything, no worries going round tight corners or on full lock
dotdog wrote:How do you drive round normally then? My car was almost undrivable with the mulitrax. It was a mission to do a u turn or go round a tight round a bout
dotdog wrote:You guys run "factory option" trd lsd dont you, apposed to real trd lsd's? Cuase ive driven brendons car and his lsd is no where near as aggressive as mine, was more like the old viscous one outa my bzr
