C52 with TRD Plate LSD & Dextron AFT fluid?
Postby Maxwedge » Fri Feb 23, 2007 12:45 pm
I was asking around about oils for Plate LSDs and a bloke from a Penrose gearbox shop recomended Auto Trans Fluid (dextron 3 type).
Sounds feasible as Auto tranmissions have wet clutches and gears?
Its not the first time I have heard of this, any ideas as I was curious?
Maxwedge
Postby Distrb » Fri Feb 23, 2007 1:09 pm
i would go with what the LSD manufacturer reccomends, which is for TRD 75w90. Obviously they're going to reccomend their own oil, but Castrol Syntrax is made in that weight and works well.
Is what i use in mine, with the same type of LSD
Distrb
Regular Poster
Postby postfach » Fri Feb 23, 2007 1:15 pm
or you could use redline 75w90, i use it in my w58 and torsen and its been fantastic
postfach
Postby sergei » Fri Feb 23, 2007 2:12 pm
Torsen does not need LSD friction additives.
Postby sergei » Fri Feb 23, 2007 2:13 pm
Distrb wrote:i would go with what the LSD manufacturer reccomends, which is for TRD 75w90. Obviously they're going to reccomend their own oil, but Castrol Syntrax is made in that weight and works well.
Oh and castrol Syntrax does not have friction additives for plate type LSD.
Postby DexGT » Fri Feb 23, 2007 5:31 pm
i use redline 75w90 oil in my c52 with a trd plate diff. it is the best oil i've used. it stopped the grabbing that was happening with the previous oils
DexGT
Postby bluemaumau » Fri Feb 23, 2007 5:42 pm
i use redline 75-90 too, but my cars not going, so i have no comment yet :cry: :lol:
Postby pc » Sat Feb 24, 2007 9:49 am
I was also recommended Castrol Syntrax for my TRD LSD (probably by the same guy). Seems to work fine.
If the LSD feels too 'grabby' you may want to add a friction modifier oil, redline make one IIRC.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Bazda » Sat Feb 24, 2007 6:36 pm
if its grabby its good, means the diff is going to try lock earlier :D
im just running castrol multitrax, i need to use a oil that will also lubricate the gear REALLY good or they will wear out oo fast and i'll end up stripping another one.
Postby dotdog » Sun Feb 25, 2007 12:36 pm
I would never run mulitrax again in a c52 with a trd lsd, I did for about two weeks and it make the diff run like a locker. I put the recomened trd oil in it and now its smooth as anything, no worries going round tight corners or on full lock
dotdog
Postby Bazda » Sun Feb 25, 2007 9:10 pm
dotdog wrote:I would never run mulitrax again in a c52 with a trd lsd, I did for about two weeks and it make the diff run like a locker. I put the recomened trd oil in it and now its smooth as anything, no worries going round tight corners or on full lock
i've been running on it for longer than that and i dont mind it. With my power and the tyres I use I need something that locks very quickly and hard. The ae101 viscous lsd couldnt hold my power it woudl jsut spin 1 wheel, with my 4agte it was perfect.
prob for normal people the reccomended stuff is good, but for me id prob rip up the gears with that stuff as i did with my other box.
Postby dotdog » Mon Feb 26, 2007 7:10 am
How do you drive round normally then? My car was almost undrivable with the mulitrax. It was a mission to do a u turn or go round a tight round a bout
dotdog
Postby neo » Mon Feb 26, 2007 1:00 pm
I have just filled my c56 with TRD plate type, with syntrax and it seems good as! (ensure your syncros are all new!)...
This cost = $95, other options
Motul FF LSD = $190 (ex Auckland)
TRD LSD = $100 (ex Japan)
neo
Postby Bazda » Mon Feb 26, 2007 5:45 pm
dotdog wrote:How do you drive round normally then? My car was almost undrivable with the mulitrax. It was a mission to do a u turn or go round a tight round a bout
mines not bad at all, same as IH8TEC his seems sweet with the same stuff.
Postby dotdog » Tue Feb 27, 2007 6:56 am
You guys run "factory option" trd lsd dont you, apposed to real trd lsd's? Cuase ive driven brendons car and his lsd is no where near as aggressive as mine, was more like the old viscous one outa my bzr
dotdog
Postby Mr Revhead » Tue Feb 27, 2007 8:03 am
no such thing as a factory option TRD diff.
Postby IH8TEC » Tue Feb 27, 2007 10:26 am
dotdog wrote:You guys run "factory option" trd lsd dont you, apposed to real trd lsd's? Cuase ive driven brendons car and his lsd is no where near as aggressive as mine, was more like the old viscous one outa my bzr
it is a trd lsd. i think it must be yor driving :lol:
Postby Bazda » Tue Feb 27, 2007 9:35 pm
who ever set the preload on your diff must of set it very tight.
