diagnostics mode idle/timing notches
Postby bluemaumau » Wed Mar 28, 2007 4:53 pm
my car runs at 2000rpm cold.
when i put it in diag mode it drops to 1500.
just wanting to know if there is a set rpm the car should be at when its in diagnostics mode, or wether its 500rpm lower etc.
i wouldve thought diagnostics mode wouldve been around 1000rpm :?
Postby sergei » Wed Mar 28, 2007 5:03 pm
actually on cars it will be slightly lower then usual normal idle because of no ignition advance. So if a car idles at say 800rpm it would drop to about 600-500rpm in diagnostic mode.
Postby bluemaumau » Wed Mar 28, 2007 5:07 pm
okay cheers sergei, ill have to recheck my ign timing
can anyone tell me 100% what each notch represents on the timing cover of a 4agze.
from the inlet side to the exhaust side
i know there are six marks but my oversize pulley covers them.
people keep giving me different answers
Postby Donor » Wed Mar 28, 2007 6:39 pm
timing cover from in to ex ae101
20,15,10,5,0,5
but then it has the pointer which is ground off with a big pulley and 3 marks in the centre of crank pulley so hmmm :wink:
Donor
Postby bluemaumau » Wed Mar 28, 2007 9:01 pm
true, doesnt that pointer point to 10btdc tho?
Postby Donor » Wed Mar 28, 2007 9:29 pm
bluemaumau wrote:true, doesnt that pointer point to 10btdc tho?
im not certain?, which out of the three marks would be 10 btdc? and why does it have the marks on the cover when there is seperate pointer and marks?weird....
Donor
Postby bluemaumau » Wed Mar 28, 2007 9:30 pm
hmm yea this could be my high idle problem, ign timing out.
im not sure would be great if anybody else has any info on this?
Postby Crucible » Wed Mar 28, 2007 9:45 pm
bluemaumau wrote:hmm yea this could be my high idle problem, ign timing out.
high idle is caused by unregulated air by passing the throttle plate weather it be a vacuum leak or faulty Aux Air valve etc, also remember piping and cooler are after the throttle plate on 4agzes and under continuous vacuum, any loose hose clips etc will act like a vacuum leak also.
bluemaumau wrote:im not sure would be great if anybody else has any info on this?
Take off the top timing cover and get it on tdc using the crankgear marks using a torch, use twink and make a mark on the cover and crank pully, now you know where tdc is. Set the base timing up approx 5-8mm before the mark on the cover and that should be sweet.
didnt I already tell you how to do this?
Crucible
Real Life Mechanic
Postby bluemaumau » Thu Mar 29, 2007 12:14 am
yea you did.
i have marked my crank pulley.
i just wondered what that pointer thingy is?
as as soon as i got the gze i put a othersized pulley on and didnt think about that thingy much more,
ive replaced all my vaccum lines and plumbing joiners, no luck
also new gaskets.
there is a brown/red valve thingy underneath the s/c outlet(pre i/c) its slightly bigger than the red and blue vsv's,
it has three lines that go to it and a plug, can you tell me what that bad boy is for? seems s/c related as 2 of the lines come from the charger and one goes to before the throttle body
Postby aesc » Thu Mar 29, 2007 9:16 am
bluemaumau wrote:there is a brown/red valve thingy underneath the s/c outlet(pre i/c) its slightly bigger than the red and blue vsv's,
Fairly sure thats the ABV you talking about
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bluemaumau » Thu Mar 29, 2007 12:53 pm
sorry id did a search its the "ACV" it spreads the load on the s/c bearings
so prolly has nothing to do with idle,
so every one agrees with 20,15,10,5,0,5 ?
every other person says something different :lol:
