when i put it in diag mode it drops to 1500.
just wanting to know if there is a set rpm the car should be at when its in diagnostics mode, or wether its 500rpm lower etc.
i wouldve thought diagnostics mode wouldve been around 1000rpm
bluemaumau wrote:hmm yea this could be my high idle problem, ign timing out.
bluemaumau wrote:im not sure would be great if anybody else has any info on this?
bluemaumau wrote:there is a brown/red valve thingy underneath the s/c outlet(pre i/c) its slightly bigger than the red and blue vsv's,
it has three lines that go to it and a plug, can you tell me what that bad boy is for? seems s/c related as 2 of the lines come from the charger and one goes to before the throttle body
