Mmm, Boost wrote:Why would bother doing that?? You'd still have all the rear diff etc in place.
I'd saying putting a 3SGTE in there would be the most cost effective way, turboing the 3SGE properly will get quite costly fast.
muppet wrote:At the moment I own a St202 Celica and like it, but I also like the GT4's better, but I don't want the 4wd sytem of the GT4.
Question is how easy is it to slap a turbo on my Celica and get it all hooked up, does the wiring need to be modified, and what parts would be need and mods done to the engine?
matt dunn wrote:We put a turbo on Mum's corona years and years ago,
was a 3SFE Carb version, converted it to EFI and ran 7psi on the standard engine. Main problem we had was trying to get a clutch to hold it.
A new Hilux clutch lasted 15 mins into the 3 hour enduro.
We put it back to normal as back then ( before the link LEM V1 even)
the aftermarket ECU made it run like shizzel and it was still mum's road car.
Mr Revhead wrote:matt dunn wrote:We put a turbo on Mum's corona years and years ago,
i remember that
i also remember you saying ya mum refused to drive it untill it was put back to normal![]()
but yeah
2 options i reckon
either do as matt suggests
or convert to 3sgte
all comes down to $$ and how much power etc you want
for fwd i reckon a stock 3sgte will be plenty.
Infinite wrote:the motor will bolt in, but a st202 lsd box wont the mounts are different im currently having mine made up for my curren.
Infinite wrote:the lsd box come in the superstrut, so if his isnt superstrut it wont fit
