Chickenman wrote:At the same point with my Blacktop.
Have been told to CRC it then use a couple of levers to gently force it off. (I can see this ending in tears)
Pulley puller FTW though.
deaf_rattle wrote:put engine at tdc
take spark plug out of cylinder where piston is at the bottom
get a soft nylon rope and feed it into the bore
then rotate the engine by hand
then get power bar onto it
works everytime
Boosted_162 wrote:The bolt is out, but cant get the pulley off. Any tips?
ee904age wrote:deaf_rattle wrote:put engine at tdc
works everytimeBoosted_162 wrote:The bolt is out, but cant get the pulley off. Any tips?
Boosted_162 wrote:Si: Ill take you up on that offer. You free wednesday?
