Removing Crank Pulley
Postby Boosted_162 » Sun Apr 22, 2007 11:40 pm
Had a search, but couldnt find anything that related.
Trying to get the crank pulley off my spare motor. The bolt is out, but cant get the pulley off. Any tips?
Postby bluemaumau » Sun Apr 22, 2007 11:43 pm
pulley puller, or drench it in crc and tap different areas of the pulley with a rubber mallet, (softly)
Postby Chickenman » Mon Apr 23, 2007 12:20 am
At the same point with my Blacktop.
Have been told to CRC it then use a couple of levers to gently force it off. (I can see this ending in tears :lol: )
Pulley puller FTW though.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Boosted_162 » Mon Apr 23, 2007 2:11 am
Chickenman wrote:At the same point with my Blacktop.
The worst part is, i cant break it. Only reason im taking it off is because RedMist needs one.
Ill see if i can get a puller.
Postby Chickenman » Mon Apr 23, 2007 2:04 pm
I think hire places do them (cowleys etc)
Baby Jesus
Chickenman
I Am The Walrus!
Postby bluemaumau » Mon Apr 23, 2007 2:09 pm
just borrow one from a mechanics
or theyre around 40 buks new
Postby Boosted_162 » Mon Apr 23, 2007 2:20 pm
Im not too keen on buying something for $40, to get something off that im selling for $40 :lol: :lol: :lol:
I have a feeling we have an ancient set round here somewhere, ill have to look.
Postby l1ttle_d3vil » Mon Apr 23, 2007 8:05 pm
even an axle puller will do the trick, definitely EXTREMELY hard to get off otherwise. i spent a whole afternoon trying to get one off every way possible once, got an axle puller and had it off in 10 minutes without breaking a sweat :roll:
Postby deaf_rattle » Mon Apr 23, 2007 8:37 pm
put engine at tdc
take spark plug out of cylinder where piston is at the bottom
get a soft nylon rope and feed it into the bore
then rotate the engine by hand
then get power bar onto it
works everytime
Postby evil_si » Mon Apr 23, 2007 9:45 pm
:lol: hey if you want to bring the ecu into town i could loan you a pulley puller :D
evil_si
Postby ee904age » Mon Apr 23, 2007 9:58 pm
deaf_rattle wrote:put engine at tdc
works everytime
Boosted_162 wrote:The bolt is out, but cant get the pulley off. Any tips?
:wink:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby deaf_rattle » Mon Apr 23, 2007 10:13 pm
works everytime
:wink:
true, hadnt read that part. use a brass or similar hammer/punch to shock it.
Postby matt dunn » Tue Apr 24, 2007 12:23 am
Just make a puller, easy as.
I have not got a picture of mine but works mint.
It's just a piece of flat bar steel with three hole drilled into it for the bolts, and the right length bolts and nuts that i found in the garage.
Two that go through the bar and bolt into the pulley,
and the centre one has a nut on the pulley side of the bar so as you screw
the centre bolt in, it pushes on the crank pulley bolt ( leave the pulley bolt in a few turns from the end )
one I get the centre bolt loose it only takes about a minute to attch the puller and pull it off.
Would post a pic but it's all packed away in my race stuff ready to go away for the weekend.
Matt
Postby sergei » Tue Apr 24, 2007 1:29 am
You might need to sacrifice an imperial spanner for your plate, as I had 5mm mild steel plate bent while trying to take off the pulley on a 20v. Imperial spanners are useless anyways (except maybe above 1" - good for smacking things and chucking in anger :lol: ).
Postby Boosted_162 » Tue Apr 24, 2007 1:37 am
I actually found a puller of some sort, had a big bolt in the middle with 2 arms (crap description), but even that couldnt get it off :?. Must be on real hard.
Si: Ill take you up on that offer. You free wednesday?
Postby evil_si » Tue Apr 24, 2007 10:46 am
Boosted_162 wrote:Si: Ill take you up on that offer. You free wednesday?
yea shud be at this stage.
gimme a buzz to arrange 021 256 0978,
or work, 270 1360 ext 224 simon in eq
evil_si
