Mr Revhead wrote:do the fault code test. double check you are shorting the correct terminals.
try starting then car and see what happens with the codes.
l1ttle_d3vil wrote:we've tried putting it in diagnostics mode but when E1 and T1 are shorted out and the ignition turned on, the check light just stays on and doesnt flash.
