Mr Revhead wrote:do the fault code test. double check you are shorting the correct terminals.
try starting then car and see what happens with the codes.
l1ttle_d3vil wrote:we've tried putting it in diagnostics mode but when E1 and T1 are shorted out and the ignition turned on, the check light just stays on and doesnt flash.
Users browsing this forum: Google [Bot] and 28 guests
