hey all, ive had a decent search for this but couldnt find anything,
im in the process of changing the front and rear engine mounts in a ae101 gt-z, the front was a piece of piss but the rear is causing some trouble, theres a slightly too small space to raise the mount so the 3 bolts on the bottom can clear the chassis where they bolt in, there is a shaft running between two suspension arms which the mount hits when i try to remove it,
so whats the best way to get around this. Unbolt the shaft? (looks pretty tricky) or some special trick i dont know about yet
