removing ae101 rear engine mount
Postby Mike- » Sat Jun 30, 2007 11:46 am
hey all, ive had a decent search for this but couldnt find anything,
im in the process of changing the front and rear engine mounts in a ae101 gt-z, the front was a piece of piss but the rear is causing some trouble, theres a slightly too small space to raise the mount so the 3 bolts on the bottom can clear the chassis where they bolt in, there is a shaft running between two suspension arms which the mount hits when i try to remove it,
so whats the best way to get around this. Unbolt the shaft? (looks pretty tricky) or some special trick i dont know about yet
Mike-
Postby 20v_rollaboy » Sat Jun 30, 2007 12:40 pm
The three bolts that bolt through the mount and onto the chassis come out.
Undo one nut at a time, just to the end of the bolt, but still on the bolt. Hit it with a hammer :lol: . Its probably going to be in there tight, so might take some effort. Repeat for the other 2 bolts. To remove the last one you might have to tighten one of the ones you have allready knocked out, but finger tight will do, just to keep the mount from bouncing up.
Hope this helps :D
20v_rollaboy
Postby AceSniper » Sat Jun 30, 2007 1:49 pm
sounds like your knocking the splined bolt out of the mount rollaboy?
Guess that is a way, I haven't touched them with out having the cross member off.
AceSniper
Postby 20v_rollaboy » Sat Jun 30, 2007 2:19 pm
Yep thats what I mean. It is a lot easier if you take the cross-member off, but not everyone has axle stands, so have to jack it up on the crossmember...
20v_rollaboy
Postby Mr.Phreak » Sat Jun 30, 2007 2:21 pm
You're a $&#$% idiot if you're undoing engine mounts with the car supported just on a jack 8O
Mr.Phreak
Postby slighty_sykotic » Sat Jun 30, 2007 2:36 pm
Mr.Phreak wrote:You're a $&#$% idiot if you're undoing engine mounts with the car supported just on a jack 8O
X100 if you hitting things with a hammer...
Couple of mounts I've done had a rubber damper thing on the top, i bashed that off with a long bar, then i could get the mount out easy :)
Dunno what the rubber bit did, it was like a solid block of rubber that sat onto of the metal casing of the mount. Nothing touched it at all. *shrugs*
--Sykotic
slighty_sykotic
Postby 20v_rollaboy » Sat Jun 30, 2007 2:55 pm
Thanks for pointing that out. I didnt say I didnt have axle stands, just that not everyone has them...
20v_rollaboy
Postby AceSniper » Sat Jun 30, 2007 3:05 pm
slighty_sykotic wrote:Couple of mounts I've done had a rubber damper thing on the top, i bashed that off with a long bar, then i could get the mount out easy :)
--Sykotic
weird thing is... that is a chunk of steel.... glued onto the mount with rubber, found out when I set one on fire to burn the rubber out of it :lol:
AceSniper
Postby slighty_sykotic » Sat Jun 30, 2007 3:09 pm
--Sykotic
Weird.... Guess you don't know what its for ethier?
slighty_sykotic
Postby Mike- » Sat Jun 30, 2007 7:04 pm
--Sykotic
lol
so ive got to take the cross member off then? where abouts do you guy put your axle stands? on the chassis rails??
Mike-
Postby Mr Revhead » Sat Jun 30, 2007 7:34 pm
that mystery piece of steel is a vibration damper.
i put the stands on the U of where the arms bolt to the chassis.
drop the north/south crossmember
when you got the mount out, bash one of the studs out and replace with a nut and bolt.
theres actually only one stud that stops you getting it out
Postby Mike- » Wed Jul 04, 2007 8:44 pm
AceSniper wrote:I haven't touched them with out having the cross member off.
are you talking north/south or east/west crossmember?
Mike-
