TRD_ZERO wrote:I went to alltech today and they will take it apart but wont put it back together unless they replace something. They said the seals for about 300-400 depending, 250 sounds good akane where did you get that done?
TRD_ZERO wrote:I wasnt complaining why they guy told me he wouldnt pull it apart and put it back together. I Fully understand why they wouldnt as he explained. They were very helpful. Where exactly do you work Chris?
TRD_ZERO wrote:So if i hand it over to you to get checked out, do you reccomend what needs to be replaced and then go from there? I got told the thrust bearing for a tdo5h (evo 4 and up style) is about $500 alone
