Turbo cleanup
Turbo cleanup
Postby TRD_ZERO » Mon Oct 08, 2007 5:25 pm
I just purchased a tdo5h evo5 for a reasonable price (second hand) NOw the guy i got it off says it had really low kms but there is a little oil here and there. Im dont want to put it onto my engine and it starts smoking and i cant guess whether its the engine or turbo. So what are my options regarding cleaning it up getting it checked out? Is anyone on this forum able to help me out?
TRD_ZERO
Postby Akane » Mon Oct 08, 2007 5:50 pm
TD05's are cheap as chips to get new seals for them. Last time I got my TD06SH done it's only $250ish
Just do it, you want new seals anyway.
Postby gleem » Mon Oct 08, 2007 9:54 pm
i have a turbo i brought off someone too, how can i check the condition of it or is there any place pref north shore that will do this for reasonably cheap?
gleem
Postby Jason T » Mon Oct 08, 2007 10:14 pm
Fixing Toyota's since '87
Jason T
Postby TRD_ZERO » Mon Oct 08, 2007 10:29 pm
I went to alltech today and they will take it apart but wont put it back together unless they replace something. They said the seals for about 300-400 depending, 250 sounds good akane where did you get that done?
TRD_ZERO
Postby Phothog » Tue Oct 09, 2007 5:56 pm
TRD_ZERO wrote:I went to alltech today and they will take it apart but wont put it back together unless they replace something. They said the seals for about 300-400 depending, 250 sounds good akane where did you get that done?
That sounds too cheap for us...
We wont pull the turbo apart & clean it up & put the old bearings, orings & pistion rings in there. it is not a wise thing to do.
you have to remmber that the turbo is spinning way way faster than the engine... (upwards of 150,000 + Rpm) and the clearances are very tight... 3odd thou between the bearings & bearing housing, same with the turbine shaft.
if we put the old worn bearings back into your freshly rebuild turbo, you spent 6 odd hours re installing it back into your car, and it poo's itself on the first test run, you will come running back saying its our fault.
just quickly priced it up, rebuild with a Genuine MHI Major kit, balance & labour is just under $600 +gst... ( if it needed that)
or just bearings, piston rings, orings, Balance & labour is $ 430+gst...
so if it just needed the indviual parts $500 is cheap for peice of mind...
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby TRD_ZERO » Tue Oct 09, 2007 6:32 pm
I wasnt complaining why they guy told me he wouldnt pull it apart and put it back together. I Fully understand why they wouldnt as he explained. They were very helpful. Where exactly do you work Chris?
TRD_ZERO
Postby Akane » Tue Oct 09, 2007 6:38 pm
Alltech Turbo, at wairau.
It was $250-$290, it's 2 something, and it was yearrrrrrrrs ago when I was pimpin' it large [sic] :roll: with the Greddy TD06.
I Vaguely remember the docket said something like new oversized bearings and seals (TD05), regrind shaft and labour.
It's less than $300 I'm sure, can't remember the very exact figure.
Postby gleem » Tue Oct 09, 2007 7:30 pm
haha im pretty sure it was you i spoke to on the phone this morning chris about the to4e
gleem
Postby Phothog » Wed Oct 10, 2007 8:24 am
TRD_ZERO wrote:I wasnt complaining why they guy told me he wouldnt pull it apart and put it back together. I Fully understand why they wouldnt as he explained. They were very helpful. Where exactly do you work Chris?
Alltech.
Gleem, yes most likley.. there is only one chris here...
Chris.
Phothog
Postby TRD_ZERO » Wed Oct 10, 2007 6:45 pm
So if i hand it over to you to get checked out, do you reccomend what needs to be replaced and then go from there? I got told the thrust bearing for a tdo5h (evo 4 and up style) is about $500 alone
TRD_ZERO
Postby Phothog » Thu Oct 11, 2007 8:31 am
TRD_ZERO wrote:So if i hand it over to you to get checked out, do you reccomend what needs to be replaced and then go from there? I got told the thrust bearing for a tdo5h (evo 4 and up style) is about $500 alone
Yes. we will pull it apart, inspect all parts & make sure they are in a good condition, (compressor wheel, Turbine shaft & wheel & Bearing housing are look at, to make sure there are no problems.)
price it up with what ever it needs, and ring you. (unless you give the go ahead if it just need minor parts.)
the Evo 4 + turbos rotate the oppisite way from "normal" TD05's
so the trust bearing is different. if it needs a thrust bearing kits are $440 +gst alone...
MHI turbos are extremly good... but if stuff gets damaged it can start to cost some money.
Chris.
Phothog
Postby TRD_ZERO » Thu Oct 11, 2007 6:12 pm
Thanks for that ill be bringing it into you guys at a later date when i get everything else sorted.
TRD_ZERO
Postby ants_ae92 » Sat Oct 13, 2007 5:44 pm
In the end if it needed to be rebuilt, it may have been cheaper to get a brand new td05 off trademe. They are going for around $700.
Hindsight is a bitch aint it
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby TRD_ZERO » Sat Oct 13, 2007 7:02 pm
NO not really im yet you get it rebuilt itf it needs one at all and the ones on trademe are evo1-3 style i think and i got a evo5 style. Which i wanted facing the other way. I didnt pay much for it in the first place. So no regrets so far.
TRD_ZERO
