d1 mule wrote:why would different heads mean a dif belt? seeing as the cam gears are the same size? are they closer together or lower in the head?
seeing as the extra displacement comes from increased stroke so the block is about 1-2cm" taller (from memory) i dont see how a blue top belt would fit, unless the gears are lower in the head, or closer together. which i doubt they are.
Bazda wrote:d1 mule wrote:why would different heads mean a dif belt? seeing as the cam gears are the same size? are they closer together or lower in the head?
the 20v cams are spaced alot closer together than a 16v.
Just google both heads and you will see.
Thats why a normal 16v belt fits a 7a block with 20v head.
