Bolt 7AFE Block to 4AGE Silvertop20V??
Postby mazdaspeednz » Mon Jul 28, 2008 3:53 pm
Ive got a Levin with a 4AGE Silvertop in it but it now has a blown bottom so seen a few things and was wondering if a 7AFE block would just bolt straight in or is there more to it than that? Any help appreciated
mazdaspeednz
Postby AE86less » Mon Jul 28, 2008 3:58 pm
No. You will need to change a few things.
Ask Bazda, he's done it and then added a turbo 8O :D
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby mazdaspeednz » Mon Jul 28, 2008 5:09 pm
I havnt been able to find much using a 20V head apart from u can use a 16v cambelt. Al i want to know is there much else needing to be done or would I be better off just with my 4age block
mazdaspeednz
Postby xsspeed » Mon Jul 28, 2008 5:46 pm
http://forums.toyspeed.org.nz/viewtopic.php?t=59730
This is Bazda's build, I suggest you read it, its pretty impressive on its own, might give you a bit more insight.
Failing that send him a PM he might be able top give you a quick list off the top of his head
Postby d1 mule » Mon Jul 28, 2008 5:59 pm
seeing as you will have both blocks it will be relatively easy, swap 4age pistons + machine gudgeons to suit, rings, bearings porsche 944 timing belt A/M comp done.
my long block cost me approx $1500 professionally built, balanced, ACL race bearings yada yada yada, was small port 16V head tho
d1 mule
Postby AceSniper » Mon Jul 28, 2008 7:24 pm
944 timing belt .... thats for a 16v head
bluetop belt for 20v head I think? use 20v oil pump
AceSniper
Postby d1 mule » Mon Jul 28, 2008 10:13 pm
why would different heads mean a dif belt? seeing as the cam gears are the same size? are they closer together or lower in the head?
seeing as the extra displacement comes from increased stroke so the block is about 1-2cm" taller (from memory) i dont see how a blue top belt would fit, unless the gears are lower in the head, or closer together. which i doubt they are.
d1 mule
Postby Bling » Mon Jul 28, 2008 10:49 pm
how big is your wallet?
small - use 4age block
big - use 7age block
Postby Bazda » Mon Jul 28, 2008 11:10 pm
d1 mule wrote:why would different heads mean a dif belt? seeing as the cam gears are the same size? are they closer together or lower in the head?
the 20v cams are spaced alot closer together than a 16v.
Just google both heads and you will see :).
Thats why a normal 16v belt fits a 7a block with 20v head.
Postby matt dunn » Tue Jul 29, 2008 5:41 pm
and the two different types of cam belt tensioners, hydraulic on BT and mechanical on ST, also give slightly different belt lengths.
