I have a issue that I've never seem to be able to solve.
My car (BZR) have random flatspots or misfiring. It only occurs at the same rev range (between 1000-3000). The car will rev, but it won't go. This issue happens when ever it feels like, and under different driving conditions. The problem goes away after I reset the ECU (disconnecting the battery for 15mins).
But it will re-occur after a few hundred k. (usually happens once or twice per tank of petrol - just to give you guys a rough idea).
I've check the leads, sparkplug, dizzy cap, recently changed ignitor.
I can only remember this started occuring after I installed a oil catch can. The can is hooked from PCV valve to can, and side of head to can, and it is vented. The PCV valve has been drilled through by the installer, so it is only functioning like link instead of opening when it is suppose to. COULD THIS BE MY PROBLEM??
Remember i have a e-manage ultimate piggyback ECU. My tuner couldn't figure out why it happens too.
I am suspecting is something to do with the Factory ECU, since the problem alway go away after i've reset it.
What do you guys think?
Cheers! and thanks in advance.
