matty_j24 wrote:abs ecu is built into the pump is it not?? all i have is a engine ecu and a abs sensor inside the car under the center console are you saying there should be a seporate abs ecu inside the car???
matty_j24 wrote:ill get someone to come round with and obd2 scan tool see if it pick up anything
