who can fix my gtt caldina
Postby matty_j24 » Sat Sep 13, 2008 4:47 pm
hey is anyone on here an auto sparky??? i have an issue with my gtt caldina abs unit staying on non stop and no engine check lights etc car is located in west auckland i need the car going asap its has had the battery put to the boot and a ma ecu2 installed but the guy who did it has touched something else somewhere and i dont know what and claims he didnt touch anything if anyone can help me txt me on 0211275706 can pay cash or trade for parts clutches cambelts waterpumps brakes whatever............
matty_j24
Postby lucasthefallen » Sat Sep 13, 2008 5:25 pm
check the relays, had this problem with a soarer recently
Need Service or Repair work done? send me a PM
lucasthefallen
Postby matty_j24 » Sat Sep 13, 2008 6:34 pm
the only thing that stops it is unpluging the abs unit
matty_j24
Postby matty_j24 » Sun Sep 14, 2008 3:34 pm
bump??? any sparkys keen to do a homer...... :roll:
matty_j24
Postby fivebob » Sun Sep 14, 2008 3:44 pm
I would suggest that you check the wires attached to the piggyback ECU are correct, and if they are can you post which ones are used.
http://www.users.on.net/~fivebob/Pages//pins.xml
Postby matty_j24 » Sun Sep 14, 2008 10:22 pm
it dosent make sense tho surely if the problem was in the wiring to the ecu when i unplug it it would cut power to the pump but so far the only things that will stop the abs unit runing is unpluging it straight off the pump or disconnecting the battery.........
matty_j24
Postby fivebob » Sun Sep 14, 2008 11:11 pm
Some of the plugs that fit the ECU also fit into the ABS computer so they may have been swapped over. IIRC the ABS plugs are a different colour to the ECU plugs, one is black the other is white.
Also the ABS computer take some inputs from the ECU to determine if it should activate the ABS, though this should stop the ABS if ther computer is dicsonnected.
Postby matty_j24 » Wed Sep 17, 2008 11:45 am
abs ecu is built into the pump is it not?? all i have is a engine ecu and a abs sensor inside the car under the center console are you saying there should be a seporate abs ecu inside the car??? i cant see any extra wiring under the dash for that...........i hope he hasnt chopped some shit out.......
matty_j24
Postby fivebob » Wed Sep 17, 2008 3:08 pm
matty_j24 wrote:abs ecu is built into the pump is it not?? all i have is a engine ecu and a abs sensor inside the car under the center console are you saying there should be a seporate abs ecu inside the car???
If it's an auto then there is one under the dash, if it's manual then it's only the one in the engine bay and swapped plugs will not be an issue.
To possibly eliminate ECU, or it's wiring, as a cause try unplugging all the ECU connectors then see if the problem is still there, other than that you'll need to check for ABS error codes.
Postby matty_j24 » Wed Sep 17, 2008 8:19 pm
yeah its a manual i have powred up the car and unplugged the ecu one by one but like i said the only thing i can see that turns it off is unplugging it direct off the pump......it has a map2 insalled into it at the moment which the guy managed to wire up wrong it has now been wired in properly kept blowing all kinds of fuses im wondering if he has put power to an earth or something and has fried something in the abs pump/computer.....ill get someone to come round with and obd2 scan tool see if it pick up anything
matty_j24
Postby fivebob » Thu Sep 18, 2008 2:45 pm
matty_j24 wrote:ill get someone to come round with and obd2 scan tool see if it pick up anything
You can check the codes without a scanner.
a) Turn off the ignition.
b) Jumper pins (13) "ТC" & (4) "CG" in connector DLCЗ.
c) Turn ignition on and read any codes.
Shorting TS(Pin 14) and CG(Pin 4) can also generate some codes but I'm not sure if these are the same or are related to the VSC/TRC system which your car doesn't have.
