4age altenator
4age altenator
Postby IKE86 » Mon Dec 01, 2008 10:54 am
#1 goes straight to the battery
#2+3 go to a dash plug i think so im guessing 1 of them is an exciter and the other is the dash light but im not sure which 1
84 Trueno ae85:current
AE92 levin:past
IKE86
Re: 4age altenator
Postby matt dunn » Mon Dec 01, 2008 4:02 pm
IKE86 wrote:#1 goes straight to the battery
Should be a diagram on the side with S I and L,
Sensing, Ignition, and Light
1 is sensing, Batt +ve
2 is light, warning light terminal
3 is ignition, switched 12V from the ign switch to turn the alt on and off.
Postby mr30%jr » Mon Dec 01, 2008 6:19 pm
mr30%jr
Postby l1ttle_d3vil » Mon Dec 01, 2008 6:22 pm
Not sure if you have the original plug or not, but if you do:
thick white is the Batt feed
black/yellow is your Ign feed
creamy yellow is the warning light feed
Postby mr30%jr » Mon Dec 01, 2008 7:19 pm
l1ttle_d3vil wrote:Not sure if you have the original plug or not, but if you do:
colours change thru the years.
mr30%jr
Postby l1ttle_d3vil » Mon Dec 01, 2008 7:33 pm
good point - the above is for a 16v 4age.
Postby IKE86 » Mon Dec 01, 2008 7:41 pm
Cool i do have it and thats what i wanted to hear :)
AE92 levin:past
IKE86
Postby rwd_mayhem » Wed Dec 10, 2008 12:42 pm
sorry to bring up an old thread but........
my colours are different. I have 1 thick cream, 1 thick cream with green stripe and a thin black with yellow strip.
Do you know what my ones are? my charge light comes on when running, not sure if it is actually charging or not though.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby mr30%jr » Wed Dec 10, 2008 2:49 pm
mr30%jr wrote:http://www.clubadub.co.nz/forum/viewtopic.php?f=4&t=10
see above link
mr30%jr
Postby l1ttle_d3vil » Wed Dec 10, 2008 5:46 pm
rwd_mayhem wrote:Do you know what my ones are? my charge light comes on when running, not sure if it is actually charging or not though.
above link should cover it, otherwise have you got a multimeter? if so, chuck that on the batt while its running. should be around 13 - 14v if its charging. will be alot lower if its not.
are the wires all different thicknesses?
on my plug, all three were obviously different gauge wire.
PM me if you still have problems.
