4age altenator
Post Reply
IKE86
4age altenator
Post by IKE86 »
#1 goes straight to the battery
#2+3 go to a dash plug i think so im guessing 1 of them is an exciter and the other is the dash light but im not sure which 1
84 Trueno ae85:current
AE92 levin:past
Contact:
Re: 4age altenator
Post by matt dunn »
IKE86 wrote:#1 goes straight to the battery
Should be a diagram on the side with S I and L,
Sensing, Ignition, and Light
1 is sensing, Batt +ve
2 is light, warning light terminal
3 is ignition, switched 12V from the ign switch to turn the alt on and off.
mr30%jr
Contact:
Post by mr30%jr »
Post by l1ttle_d3vil »
Not sure if you have the original plug or not, but if you do:
thick white is the Batt feed
black/yellow is your Ign feed
creamy yellow is the warning light feed
mr30%jr
Contact:
Post by mr30%jr »
l1ttle_d3vil wrote:Not sure if you have the original plug or not, but if you do:
colours change thru the years.
good point - the above is for a 16v 4age.
IKE86
Post by IKE86 »
Cool i do have it and thats what i wanted to hear :)
AE92 levin:past
rwd_mayhem
Post by rwd_mayhem »
sorry to bring up an old thread but........
my colours are different. I have 1 thick cream, 1 thick cream with green stripe and a thin black with yellow strip.
Do you know what my ones are? my charge light comes on when running, not sure if it is actually charging or not though.
current: 1975 Valiant Regel
mr30%jr
Contact:
Post by mr30%jr »
mr30%jr wrote:http://www.clubadub.co.nz/forum/viewtopic.php?f=4&t=10
see above link
rwd_mayhem wrote:Do you know what my ones are? my charge light comes on when running, not sure if it is actually charging or not though.
above link should cover it, otherwise have you got a multimeter? if so, chuck that on the batt while its running. should be around 13 - 14v if its charging. will be alot lower if its not.
are the wires all different thicknesses?
on my plug, all three were obviously different gauge wire.
PM me if you still have problems.
Post Reply
