Fuel tank question
Fuel tank question
Postby Vertigo » Sat Dec 27, 2008 8:11 am
hey, so ill be dropping a 4AGE 16v into my AE80 that currently has a 2A 8v carby. im sure it currently has a fuel tank with built in fuel pump, which will no doubt be designed for carb engines and thoroughly unsuitable for the 4AGE. should i:
a) get new fuel tank with external fuel pump
b) replace fuel pump with an EFI internal pump, using existing tank
c) not bother at all, and hope the current pump works??
TVIS just kicked in, yo!
Vertigo
Postby Jonno2002 » Sat Dec 27, 2008 8:23 am
carbys usually have a mechanical pump at the motor dont they, id say you need to get an efi tank or rangi up and external high pressure pump, and remember efi needs a return too which the carb tank may not have, all the fun things to think about
Jonno2002
Postby matt dunn » Sat Dec 27, 2008 10:51 am
how about just get and efi tank with internal pump from an AE82 FX or similar?
I take it your car will be similar shape being EE8#?
You will still need to run a return line no matter what you do.
Postby xsspeed » Sat Dec 27, 2008 11:09 am
I'm doing the same with my EE80, (except I have to change engine mounts). I have an FXGT parts car that I am using to get all the efi gear out of, so I would suggest the same.
The carby motors ahve a sender in the fuel tank and a mechanical pump at the engine. Its all much lower pressure than an efi setup.
You will also need to replace your rubber fuel lines with efi rated ones. Some people leave them But I will change mine just to be safe. I am pretty sure the copper(?) fuel lines that run from the tank forward will be sweet though, I haven't looked into that yet
Postby Vertigo » Sun Dec 28, 2008 9:00 am
thanks guys.
so, what tanks might fit in an AE80 vintage rolla dx sedan? and if i do decide to rangi up a solution, could i just drill (after emptying and cleaning the tank of course!) and weld a return fitting into my current tank? seems the easier option. then grab an external pump. might go that way.
Vertigo
I have an ae82 tank
Postby fxgt race » Sun Dec 28, 2008 9:20 am
I have an ae82 tank that i have just taken out, it has an up rated fuel pump in it as well as it was used in my race car
fxgt race
Postby evil_si » Sun Dec 28, 2008 9:53 am
i usually modify the existing fuel tank,
imo its easier and you know the tank is going to fit no worries
carb systems run low pressure the factory rubber hose will not withstand the pressure from a efi pump,
most carb setups have a mechanical lift pump on the engine, nothing in tank.
the carb feed out of the tank is usually small,
i use the factory fuel supply as the return, any return fuel isnt under much pressure, the carb fuel lines handle it fine
i then weld in a new fuel pick up and supply into the tank, normally 3/8 in size and run new fuel lines to the engine as required,
and run an external fuel pump
copper line is fine to use, i like to weld fittings on the end of it to use pushlock hose tails etc, not a big fan of just hose clamping rubber hose to the copper tube,
keep in mind that most of the fuel hose from supercheap / repco etc is low pressure not rated for efi, it does tend to swell up and burst
it can take a bit of hunting around to find the right stuff, its usually around $45pm anything a lot cheaper id be wary of.
i usually go straight to hydralink,
evil_si
Postby matt dunn » Sun Dec 28, 2008 12:44 pm
evil_si wrote:i usually modify the existing fuel tank,
Does that give fuel surge problems?
As I thought EFI tanks had fuel bowls in them and Carb ones dont as the carb acts as the surge tank?
I know the older stuff was like that.
Postby Vertigo » Sun Dec 28, 2008 1:13 pm
hmmm, so long as the tank is kept near full, it should be ok? its not for racing, just a daily driver + fun :)
Vertigo
Postby evil_si » Sun Dec 28, 2008 2:21 pm
i havent had any issues with surge before,
then again if there was any doubt or if it was a serious weapon i would fit an additional pump and a surge tank to the system
evil_si
Postby Flannelman » Mon Dec 29, 2008 9:11 pm
do NOT use copper lines!!
with age they become brittle and break leading to a fuel leak and potentual fire.
Use steel lines
Flannelman
formerly known as Affroman
Postby crispy'86 » Tue Dec 30, 2008 12:08 am
Hey Vertigo. If you want to ditch your carb wiring loom can you flick a pm my way? I'm needing to temporarily go the other way. from EFI back to carb to run my race engine in on the road. So won't be needing to use loom for the sensors etc
crispy'86
Postby Vertigo » Tue Dec 30, 2008 8:50 am
my current loom is for a 2A engine, probably unsuitable for you if you have a 4AGE. i wont be taking it out of the car for a while yet anyway, but if you can wait a few months, ill probably have it out by then.
Vertigo
