autotensioner on a silvertop?
Postby bigt » Sat Dec 27, 2008 10:08 am
does the 4age silvertop have a cambelt autotensioner?- not from what ive read- went to order parts to do my cambelt and they( was'nt toyota ) told me that i needed to include a seal kit for my autotensioner as well as a new belt idle tensioner ?- can anyone set me straight
bigt
Postby deaf_rattle » Sat Dec 27, 2008 10:10 am
talk to mark on here ( 1I1 )
he will sort you out.
Just buy genuine cambelt tensioner and you will be fine.
Postby neo » Sat Dec 27, 2008 10:14 am
The seal kit will be the cam seals and crank seal.
The autotensioner isnt re-usable and while your there doing the seals isnt a biggie.
neo
Postby bigt » Sat Dec 27, 2008 10:15 am
thanks man
bigt
Postby matt dunn » Sat Dec 27, 2008 10:49 am
neo wrote:The seal kit will be the cam seals and crank seal.
Auto re-tensioner?
Silvertop's dont have auto re-tensioners, unless you call the spring that pulls on the adjuster an auto tensioner, but you need to lock the centre bolt anyway, so it really does nothing,
and the Blacktops have hydraulic tensioners, but they are normally re-useable if you deal with them correctly.
Normally on a ST you'd do the belt and the adjustment pulley,
and on a BT you'd do the belt and the hydro adjuster to be sure.
Postby bigt » Sat Dec 27, 2008 2:54 pm
yeah thats what i thought- havent done a timing belt before so have done a bit of research- confused me when the parts shop gave me the wrong info- thanks again
bigt
Postby Bling » Sat Dec 27, 2008 3:42 pm
"parts shop"
Thats your first mistake :lol: I'm not going to knock aftermarket parts, but for parts like you're after I would only buy genuine. Check the sponsors section of the forum above as mentioned above. Mark can get you anything toyota at good prices.
also
matt dunn wrote:and the Blacktops have hydraulic tensioners, but they are normally re-useable if you deal with them correctly.
Really worth trying to saving a few $$$ there? :?
Postby Mr Revhead » Sat Dec 27, 2008 3:51 pm
i would definitely NOT reuse a blacktop tensioner thats done 100k they DO NOT last 200k
i think matt is referring to reusing them when rebuilding low kay engines, ie for his race car
when at toyota the only auto tensioners i heard of failing were the blacktop ones and the 1kz ones
Postby Bling » Sat Dec 27, 2008 3:56 pm
Yeah I guessed that might be the case, just don't want people getting the idea that its fine to try reuse on a road car with 100k :lol:
"but I read on toyspeed it would be fine!" :wink:
Postby Burning Angel » Sat Dec 27, 2008 5:54 pm
the problem with certain parts places is that the computer lists both types for the 20v and doesn't say one for blacktop, one for silver.
so unless the salesperson knows anything about 4ages your prob gunna get the wrong parts
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Mr Revhead » Sat Dec 27, 2008 6:02 pm
yep. BNT computer
Postby matt dunn » Sat Dec 27, 2008 6:46 pm
matt dunn wrote: on a BT you'd do the belt and the hydro adjuster to be sure.
Postby rollaholic » Sat Dec 27, 2008 9:17 pm
yeah toyota geunine parts are insanely reasonable when it comes to cambelt stuff, their prices are all standardised and for the peace of mind / ease of fitment you get from genuine parts i personally dont even bother ringing partmaster and the like when we got a toyota cambelt to do.
