neo wrote:The seal kit will be the cam seals and crank seal.
The autotensioner isnt re-usable and while your there doing the seals isnt a biggie.
matt dunn wrote:and the Blacktops have hydraulic tensioners, but they are normally re-useable if you deal with them correctly.
BZG|Bling wrote:matt dunn wrote:and the Blacktops have hydraulic tensioners, but they are normally re-useable if you deal with them correctly.
Really worth trying to saving a few $$$ there?
matt dunn wrote: on a BT you'd do the belt and the hydro adjuster to be sure.
