MrOizo wrote:Shitttt where have you been hiding!!??!??!
Nu-Del wrote:Under many a Nissan powered rock but am building something very different now
Nu-Del wrote:Anyone here done it? got any tips or tricks?
Have a 94 Supra motor and will be running a Link G4 Storm, DSR T3/T4 and Either a Driven Performance manifold or something similar. Im probably just going to run the standard injectors etc at first just to see how much I can get out of it befor trading up to bigger injectors.
BlakeNZ wrote:about 205-210rwkw will max out the standard 315cc injectors. best bolt in the 1jzgte 380cc ones or 2jzgte 430cc ones. not expensive.
FLAWLES wrote:you should wheigh up cost of parts vs comp 2jzgte engine before attacking a na/t 2jz bulid
Py7h0n wrote:Actually there is a fair bit more than the compression ratio and the oil squirters.
The wonky over engine plenum and TB
The old distributor ignition which can cause issues when asking for power
The lower flowing oil pump
Much smaller market for head parts (Exhaust cam especially)
Your better off starting with a 2JZ-GTE.
If you are looking for a cheaper option look at a 1JZ-GTE head, oil pump and sensors on the 2JZ-GE block. That at least gets you a better platform for future parts. I will warn you though compression rises with a 1JZ head so you will need to do something about that.
GTCRSHR wrote:Nu-Del wrote:I already have the Link G4
