anyone know what this is? (AE86)
Postby Mr-Hiney » Mon Apr 06, 2009 11:34 pm
[Posted for Stalker]
Anyone know what this is? its pressed by the clutch pedal and the wires go to (what they think is) the old ECU harness and the other wire looks to go to the gauge cluster.....
S14 Silvia K's (Freshly RB25DET powered)
Mr-Hiney
Postby thegreatestben » Mon Apr 06, 2009 11:36 pm
Clutch switch, let's ecu know when you've got your foot on the clutch
Or
Starter doesn't work unless your foot is on clutch to stop you from starting in gear with clutch engaged.
thegreatestben
Postby cat007 » Tue Apr 07, 2009 9:05 am
Or cruise control - will turn it off when clutch is de-pressed
Postby stalker » Tue Apr 07, 2009 9:57 am
It wouldnt be a factory thing aye?
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby Alex B » Tue Apr 07, 2009 10:01 am
It would be.
Postby stalker » Tue Apr 07, 2009 12:47 pm
sweeet...I have finally found out what it is!!
Just incase anyone else finds one in their ae85:
Whats the car? Guessing you have an AE85, the switch is not on other models. (Assuming it's a AE85/86).
The switch is used to tell the motor to run leaner when no power is needed. So the motor should idle leaner, which produces less emisions.
You no longer need it, but it acts as a pedal height adjuster as you know.
8)
stalker
Postby ee904age » Tue Apr 07, 2009 7:02 pm
Sounds like bollocks to me.
Who idles long enough with the clutch in to warrant having something like this??? If Toyota went to that much trouble to make a car run leaner when no power is req'd, wouldn't they based it on vacuum so its actually working long enough to have an effect on emissions?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby stalker » Tue Apr 07, 2009 7:07 pm
Just going by what I was told...
stalker
Postby thegreatestben » Tue Apr 07, 2009 8:09 pm
Concur.
thegreatestben
Postby stalker » Tue Apr 07, 2009 8:20 pm
Two forums, both conflicting evidance. :lol: :roll:
what and where is that manual you have Ben? Looks like it could be very handy.
stalker
Postby thegreatestben » Tue Apr 07, 2009 8:22 pm
BGB for AW11, would be very suprised if the switch in your ae8* is any different.
thegreatestben
Postby d1 mule » Tue Apr 07, 2009 8:36 pm
tp date iv now had 5 ae85/6 and they have all started with the clutch in or out
d1 mule
Postby Malcolm » Tue Apr 07, 2009 9:58 pm
that's a ridiculous comment about running leaner. The ecu uses TPS (and MAP) to calculate load, and at no load (closed throttle) it already runs as lean as is necessary for a car that is idling, noone who is intelligent enough to develop an EFI system for a major automotive manufacturer would ever be stupid enough to employ a clutch switch for load sensing. Laughable! :lol:
Postby Xyrath 86 » Wed Apr 08, 2009 12:19 am
That comment was about a 3A. Those things have all sorts of emissions crap on them so it wouldn't surprise me.
Xyrath 86
Postby Alex B » Wed Apr 08, 2009 12:25 am
Heh my old sprinter had so much emission control stuff it had a computer, it wasnt efi. :lol:
Postby frost » Wed Apr 08, 2009 2:09 am
pyro_sniper2002 wrote:Heh my old sprinter had so much emission control stuff it had a computer, it wasnt efi. :lol:
ae85 also has this computer, and yeah i would side on the emissions control thing, as the car starts weather clutch is in or out,
and when doing a conversion to 4age, ripping out the emissions crap makes that button dead/no power.
also your car is a ae85 not ae86 unless you have put a ae85 pedal box in there, as i can see the conversion from cable clutch to hydro.
Postby stalker » Wed Apr 08, 2009 2:24 am
frost wrote:also your car is a ae85 not ae86 unless you have put a ae85 pedal box in there, as i can see the conversion from cable clutch to hydro.
I didnt say 86, that was the flatty posting for me. Mines 85 as said above.
I guess its safe to assume (what ever it is) that I can rip it and its wires out without worrying about it lol
stalker
Postby RomanV » Wed Apr 08, 2009 2:31 am
Is your car NZ new by any chance?
Non Jap models always seem to get a few more things to 'idiot proof' their cars.
Postby frost » Wed Apr 08, 2009 2:33 am
oh i didnt see it was posted by two people.
and ae86 manual (page cl3) just says clutch pedal adjuster so you may still need it.
though its a bad cartoon picture and cant see clearly if its the same thing.
Postby stalker » Wed Apr 08, 2009 2:34 am
Nah, mines an import.
And yea, wondered about that, but decided that I would get a pedal box for it..so hopefully I wont have to add it in lol
stalker
