Anyone know what this is? its pressed by the clutch pedal and the wires go to (what they think is) the old ECU harness and the other wire looks to go to the gauge cluster.....
Whats the car? Guessing you have an AE85, the switch is not on other models. (Assuming it's a AE85/86).
The switch is used to tell the motor to run leaner when no power is needed. So the motor should idle leaner, which produces less emisions.
You no longer need it, but it acts as a pedal height adjuster as you know.
ee904age wrote:Whats the car? Guessing you have an AE85, the switch is not on other models. (Assuming it's a AE85/86).
Sounds like bollocks to me.
Who idles long enough with the clutch in to warrant having something like this??? If Toyota went to that much trouble to make a car run leaner when no power is req'd, wouldn't they based it on vacuum so its actually working long enough to have an effect on emissions?
pyro_sniper2002 wrote:Heh my old sprinter had so much emission control stuff it had a computer, it wasnt efi.
frost wrote:also your car is a ae85 not ae86 unless you have put a ae85 pedal box in there, as i can see the conversion from cable clutch to hydro.
stalker wrote:frost wrote:also your car is a ae85 not ae86 unless you have put a ae85 pedal box in there, as i can see the conversion from cable clutch to hydro.
I didnt say 86, that was the flatty posting for me. Mines 85 as said above.
I guess its safe to assume (what ever it is) that I can rip it and its wires out without worrying about it lol
