Car suddenly wont start
Postby DriftSpecStarlet » Wed Apr 29, 2009 9:52 pm
Drove home fine,
Now sitting on a level surface with full tank of gas,
It will fire up roughly for 2 seconds then fully die, if you plant your foot when you start it, it will rev as high as it can for 2 seconds then completely die,
ST185 with 3sgte
:) Help VERY appreciated as i need to drive it to napier for Re-Vin... Would help if i could actually GET there :)
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby Boosted_162 » Wed Apr 29, 2009 9:57 pm
Sounds like bung AFM to me, is similar symptoms to my old facelift.
Bridge B+ and FP in the diagnostics port. This will make the fuel pump run permanently. The problem with bung afm is the car thinks its not sucking in any air so wont supply fuel.
Postby DriftSpecStarlet » Wed Apr 29, 2009 10:06 pm
Hey mate thanks for quick help, Have the fuel pump already wired up to a switch on the dash :) and you can hear the fuel rushing through the car with everything turned off but the fuel pump,
But you say dodgey AFM? I am thinking the same thing myself... stupid bloody things.
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby Lloyd » Wed Apr 29, 2009 10:16 pm
Does it stutter and then die or simply cut out?
Postby DriftSpecStarlet » Wed Apr 29, 2009 10:20 pm
Well i sprayed it in degreaser :P as ya do...
Then i started it up and it idled nicely for about 2 minutes then just died... turned it on a couple more times and its idle time was decreasing, now its gotten to the point where it is Sputtering and then cutting out
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby DriftSpecStarlet » Wed Apr 29, 2009 10:23 pm
Oh yeah it has also had this problem before once but it kind of just fixed itself...
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby l1ttle_d3vil » Wed Apr 29, 2009 10:27 pm
check your spark plugs aren't fouled, clean them and put them back in, or just chuck some new ones in to be sure.
make sure injectors are actually firing too, might only be firing off the cold start fuel or something weird??
Postby DriftSpecStarlet » Wed Apr 29, 2009 10:34 pm
its got some new very expencive iridiums
also has brand new 8mm leads and coil lead
Cold start injector isnt connected and never has been
Grrr lol...
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby Boosted_162 » Wed Apr 29, 2009 10:48 pm
DriftSpecStarlet wrote:Well i sprayed it in degreaser :P as ya do...
Now thats sounding like the problem i had with my RC. Is it pulling up any error codes? Mine did exactly that, and had error code 14. Ended up having a fried ecu.
Postby Lloyd » Wed Apr 29, 2009 10:59 pm
Pull plugs and check them anyway. Always the best place to start
Postby gepsk8 » Thu Apr 30, 2009 7:14 pm
full tank of gas? u sure its petrol in tank? sound u could have put diesel in it.
O272754663
gepsk8
Postby DriftSpecStarlet » Thu Apr 30, 2009 7:26 pm
98 mate ;) the good stuff :)
Ohh really? Good thing i have a spare ECU... Car is now just cranking over no firing... changed coil leads and HT leads
edit* gas is coming out the exhaust so it is getting fuel :)
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby gepsk8 » Thu Apr 30, 2009 7:39 pm
i would be pulling plugs. smell them? propably fouled
O272754663
gepsk8
Postby DriftSpecStarlet » Thu Apr 30, 2009 7:47 pm
okay ill swap the ECU then check the plugs, what would cause the fouling though? and wtf is fouling?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby gepsk8 » Thu Apr 30, 2009 7:54 pm
over fueling e.g no spark. when plug is as black as ace of spades(all over) or dripping wet.
O272754663
gepsk8
Postby DriftSpecStarlet » Thu Apr 30, 2009 8:09 pm
ahhh cheers ill give that a shot :) HOPEFULLY it fixes these stupid problems.... How do you diagnose which code is being sent when check light is on?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby l1ttle_d3vil » Thu Apr 30, 2009 8:27 pm
yeah if plugs are wet if won't be firing. if you're not sure if plugs are wet, spray some engine start down the inlet manifold, close throttle and crank it. if it fires you got a fueling problem.
or pull a spark plug out and clamp it to an earth (engine hook or something) with some vice grips, attach ht lead and crank it to see if theres spark.
expensive iridium plugs can get fouled too :wink: replace them with cheap plugs from toyota just to check, i get mine for about $3 each. it can be caused from the engine running too rich, which could be caused by faulty water temp reading, map reading, TPS reading etc etc.
Postby sergei » Thu Apr 30, 2009 10:31 pm
It could be fuel pump...
Postby 20v_rollaboy » Thu Apr 30, 2009 10:37 pm
DriftSpecStarlet wrote:Hey mate thanks for quick help, Have the fuel pump already wired up to a switch on the dash :) and you can hear the fuel rushing through the car with everything turned off
20v_rollaboy
Postby sergei » Fri May 01, 2009 8:54 am
It doesn't mean the fuel pump is half dead. It has only enough flow to prime but not enough to keep running...
But problem could be entirely else...
