Now sitting on a level surface with full tank of gas,
It will fire up roughly for 2 seconds then fully die, if you plant your foot when you start it, it will rev as high as it can for 2 seconds then completely die,
ST185 with 3sgte
DriftSpecStarlet wrote:Well i sprayed it in degreaseras ya do...
Then i started it up and it idled nicely for about 2 minutes then just died... turned it on a couple more times and its idle time was decreasing, now its gotten to the point where it is Sputtering and then cutting out
DriftSpecStarlet wrote:Hey mate thanks for quick help, Have the fuel pump already wired up to a switch on the dashand you can hear the fuel rushing through the car with everything turned off
20v_rollaboy wrote:DriftSpecStarlet wrote:Hey mate thanks for quick help, Have the fuel pump already wired up to a switch on the dashand you can hear the fuel rushing through the car with everything turned off
