JZX100 1JZ Manual Conversion Questions
Postby xnickx » Mon May 25, 2009 9:15 pm
Tried the search but nothing came up quite relevant?!
OK so the car is a JZX100 Chaser with a 1JZGTE, currently running the 4AT trans, and wanting to convert to manual the easiest way (also cheapest I guess) by using a W5# box and have the following questions:
1) If I was to use a W5# box, would I need a custom A1 Turbos bellhousing to mate it to the 1J?
I know that the W58 came in the JZA80 2JZGE, seeing they would mate up to a 2JZ would that mean it will mate to a 1JZ aswell?
2) When using a W5#, are there many mods to the gearbox cross member needed? Or possibly use the auto cross member and just mod that?
3) Would other car's pedal box and pedals match up to the JZX100?
4) What do you guys do with the inhibitor switch? With the RBs we just shorted a circuit and that worked, what do we do in a 1JZ?
5) What else should be considered with the conversion (apart from the usual cylinders, lines, driveshaft etc etc)
Thanks in advance for the response(s)
Nick
xnickx
Postby MrOizo » Mon May 25, 2009 9:24 pm
Arent the Auto ECU's intergrated into the engine ECU or are they independent? I know there are Apexi Power FC's for the Manuals only - well so i have been told..
1) A 2JZ bell housing will be all gravy. its just the hassle of fining one but since you work at toyota you should be able to find something new for cheap cheap :)
2) There should be something out there with the right config for the crossmember.
3) Not sure? :o Maybe the JZX90 ones are close?
4) The switch can be simply be bypassed when you do the wiring.
5) The driveshaft matching will be hard i think. maybe able to get away with shortening the front half?
MrOizo
Toyspeed Legend
Postby xnickx » Mon May 25, 2009 10:06 pm
MrOizo wrote:Arent the Auto ECU's intergrated into the engine ECU or are they independent? I know there are Apexi Power FC's for the Manuals only - well so i have been told..
Ekk pass not sure? Anyone able to shed some light here?
MrOizo wrote:1) A 2JZ bell housing will be all gravy. its just the hassle of fining one but since you work at toyota you should be able to find something new for cheap cheap :)
Ahhh so just any 2JZ to W58 will do? Not sure if a genuine new one will be that much cheaper these days considering the exchange rate is silly at about 50-55Yen per NZD!
MrOizo wrote:4) The switch can be simply be bypassed when you do the wiring.
So just join the inhibitor switch back into itself so it think its in D the whole time? Makes sense..
MrOizo wrote:5) The driveshaft matching will be hard i think. maybe able to get away with shortening the front half?
Yeah will probably just get it shortened at this stage, saw a link somewhere here a few days ago can probably still dig it up :)
xnickx
Postby strx7 » Mon May 25, 2009 10:11 pm
Nope cause it will never start.
It needs to be in Neutral or Park
Postby xnickx » Mon May 25, 2009 10:16 pm
strx7 wrote:Nope cause it will never start.
Ops yes that's what I ment!
xnickx
Postby escortman » Mon May 25, 2009 10:56 pm
the auto 1 fits if u snap it in the middle :oops: :lol:
4x4 toyota blizzard offroader
escortman
Postby xnickx » Tue May 26, 2009 10:40 am
escortman wrote:the auto 1 fits if u snap it in the middle :oops: :lol:
The cross member or the pedal?
xnickx
Postby FLAWLES » Tue May 26, 2009 10:48 am
yes the auto ecu's are in intergrated in with the engine ecu
its all one
manual ecu's for jzx100's are cheap as chips ex yahoo jp but you will still end up paying around 200nzd for one
you can use ee101 ( i think from memory ) pedal box's but you have to drill one extra hole in it
with a w5* box there shorter than a r154 box and you may ( unsure ) have to cut a nother linkage hole further up the tunnel
save up and just by a extrenal linkage r154 box bolt in fit no cutting shit
trent at totally toyota normal has auto to manual conversion kits for sale with everything for around $2500 to 3g incl flywheel and clutch etc
less hassle
from memory as well the auto drive shafts are the same as manual
FLAWLES
Postby FLAWLES » Tue May 26, 2009 10:50 am
FLAWLES
Postby iOnic » Tue May 26, 2009 10:52 am
As for the pfc, the chaser is one of the only automatic cars apexi does a pfc for. it has a special menu where you can modify shift patterns etc
Postby MrOizo » Tue May 26, 2009 11:07 am
Oops! got my story wrong :o my bad
MrOizo
Toyspeed Legend
manual conversion
Postby docTRD » Wed May 27, 2009 12:16 am
hey there ive done a manual conversion on a 90 series chaser a few years ago, should be very similar if not identical as a 100 to convert. this is what i used :
1) gx81 clutch pedal and master cyl, and slave cyl and hydraulic line. The gx81 pedal just needed a hole to be drilled in the pedal for the bolt to the master cyl go through and slip pin, easy.
2) w58 remote shift gearbox. You will have to press the tunnel up a bit as the gearbox hits the tunnel, did on the 90 ,not sure about 100.
3) auto x-member reused.
4) get the niteparts flywheel and bell or genuine toyota 2jzge ones.
5) heavy duty clutch kit
6) for the neutral start switch, i took out the whole selector armature from the auto box, made sure it was in neutral then cable tied it in that position. Tucked the unit onto the manual box. ecu thinks its in neutral and starts, no cutting wires needed.
easy conversion overall. see how u go
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby xnickx » Wed May 27, 2009 1:11 pm
Thanks for all the responses.
Found that the W58 came out of the JZA80 2JZGE which will bolt straight onto the 1JZGTE.
Anyone know if the W58 in the JZA80 Supra was remote/rear/normal shifter?
Cheers again
xnickx
Postby evil_si » Wed May 27, 2009 1:22 pm
xnickx wrote:Thanks for all the responses.
Cheers again
from memory its a remote setup
evil_si
Postby edwagon » Wed May 27, 2009 2:20 pm
Yep jza80 def remote.
edwagon
Postby FLAWLES » Wed May 27, 2009 2:57 pm
whats the over all length of the remote shiter w58?
FLAWLES
Postby xnickx » Wed May 27, 2009 3:46 pm
evil_si wrote:from memory its a remote setup
edwagon wrote:Yep jza80 def remote
Brilliant! Thanks for that guys!
xnickx
Postby MrOizo » Mon Jun 01, 2009 11:11 pm
MrOizo
Toyspeed Legend
Postby escortman » Tue Jun 02, 2009 7:36 am
the crossmember
escortman
Postby FLAWLES » Wed Jun 03, 2009 11:30 am
sorry i put you wrong
the jzx100 auto drive shafts are 70mm shorter than the manaul ones
FLAWLES
