MrOizo wrote:Arent the Auto ECU's intergrated into the engine ECU or are they independent? I know there are Apexi Power FC's for the Manuals only - well so i have been told..
MrOizo wrote:1) A 2JZ bell housing will be all gravy. its just the hassle of fining one but since you work at toyota you should be able to find something new for cheap cheap
MrOizo wrote:4) The switch can be simply be bypassed when you do the wiring.
MrOizo wrote:5) The driveshaft matching will be hard i think. maybe able to get away with shortening the front half?
xnickx wrote:
So just join the inhibitor switch back into itself so it think its in D the whole time? Makes sense..
iOnic wrote:MrOizo wrote:Arent the Auto ECU's intergrated into the engine ECU or are they independent? I know there are Apexi Power FC's for the Manuals only - well so i have been told..
As for the pfc, the chaser is one of the only automatic cars apexi does a pfc for. it has a special menu where you can modify shift patterns etc
xnickx wrote:Thanks for all the responses.
Found that the W58 came out of the JZA80 2JZGE which will bolt straight onto the 1JZGTE.
Anyone know if the W58 in the JZA80 Supra was remote/rear/normal shifter?
Cheers again
xnickx wrote:escortman wrote:the auto 1 fits if u snap it in the middle![]()
The cross member or the pedal?
