I am looking for the vacuum pump to run a brake booster on a diesel, and heard that possibly MR2 and Estima/Emina vans have an electric pump?
Any truth to the rumours, and if so, how much are they?
Cheers.
KwS wrote:good point about the mr2..... i know ones with power steer use an electric pump for that, but do they run a vacuum line all the way up to the front for the brake booster, or is it indeed electric?
the fallen303 wrote:twin turbo jzs147 aristo's run a electronic/nitrogen brake booster if that helps. my uncle was looking at using one on a kit car at one point...
Rob wrote:The late lucida diesels have a vacum pump on the rocker cover which is run off the cam by an arm on a lobe. Early ones still have a front pump on the alternator
