deep cycle battery
deep cycle battery
Postby deaf_rattle » Tue Jul 14, 2009 5:14 pm
My orbital battery went flat and i have had it on charge for the last couple of days. The battery charger always shows charging and the "charged" light hasnt come on.
Tested battery with multi meter and i got 11.93volts
is this ok? or is my battery on its way out?
Postby Bling » Tue Jul 14, 2009 5:41 pm
To know for sure i'd get it checked out. 11.93v is a bit low. But even if it read 12.5 it could be stuffed still.
Re: deep cycle battery
Postby sergei » Tue Jul 14, 2009 5:47 pm
deaf_rattle wrote:My orbital battery went flat and i have had it on charge for the last couple of days. The battery charger always shows charging and the "charged" light hasnt come on.
Which colour is the orbital battery?
and what charger?
Postby deaf_rattle » Tue Jul 14, 2009 6:06 pm
battery is a fusion branded version of this
http://www.remybattery.com/Products/Exi ... 34XCD.aspx
charger is a arlec compact 2500
http://www.trademe.co.nz/Trade-Me-Motor ... 162348.htm
Postby Bling » Tue Jul 14, 2009 6:12 pm
Just as a side note... its amazing what people will pay on trademe. That same charger is cheaper new @ Kmart :lol:
Postby Alex B » Tue Jul 14, 2009 6:23 pm
A multimeter wont tell you a whole lot about the battery's condition. Need to load test it, most battery shops will do it for nicks.
Postby deaf_rattle » Tue Jul 14, 2009 6:26 pm
BZG|Bling wrote:Just as a side note... its amazing what people will pay on trademe. That same charger is cheaper new @ Kmart :lol:
yeah i didnt get it off trade me, think i bought it from mitre10 for next to nothing.
I have a load tester, but didnt want to load test it until it was properly charged.
Postby evil_si » Tue Jul 14, 2009 7:50 pm
sounds like the battery needs a good wakeup, using a decent high amp, high power charger,
evil_si
Postby matt dunn » Tue Jul 14, 2009 8:39 pm
11.93 volts tells me your voltmeter or charger are faulty.
Postby Prymal » Tue Jul 14, 2009 8:40 pm
try to get your hands on a ctek charger - multi 7000 if possible
This is what i use to charge my oddyessy gel cell ..
the charger seems a bit weak , and may have issues cycling up a deep cycle battery like the one you have
Prymal
Postby deaf_rattle » Tue Jul 14, 2009 8:42 pm
classique71 wrote:try to get your hands on a ctek charger - multi 7000 if possible
yeah thats true, i might have to put it into a car and take it for a drive.
Postby B1NZ » Tue Jul 14, 2009 9:00 pm
how muchy at k-mart?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby matt dunn » Tue Jul 14, 2009 10:26 pm
On a side note, the new calcium batteries wont charge form the car if they get flat enough,
if you leave the lights on and flatten it, jump start it and drive the length of NZ, it wont be charged.
That is causing a lot of issue's.
Postby sergei » Wed Jul 15, 2009 9:21 am
I have the same charger and couple of orbital batteries (yellow top and red top), that charger will take forever to charge those batteries, best bet is to connect the battery to a running car with jumper leads (15 min perhaps), as the charger will only supply barely 2A. The charger is designed for shitty 25Ah batteries (NS40 and such), spiral cell batteries are a lot different in characteristics.
Postby GTCRSHR » Wed Jul 15, 2009 10:26 am
take it to "Battery Centre" i think they are called they will chuck it on a decent charger ,
Nothing to see here ...
GTCRSHR
Postby Bling » Wed Jul 15, 2009 11:39 am
$19.99 last time I checked
Postby NZ_AE86 » Wed Jul 15, 2009 8:48 pm
This is driving me crazy at the moment! I need a t-shirt with this info so I don't need to tell every customer the same story that they then don't agree with!
How much does your orbital battery weigh? If it is underweight then it is throw away time as it will never hold a charge properly.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby jondee86 » Thu Jul 16, 2009 8:22 pm
matt dunn wrote:On a side note, the new calcium batteries won't charge from the car if they
get flat enough. If you leave the lights on and flatten it, jump start it and
drive the length of NZ, it wont be charged. That is causing a lot of issue's.
Sooooo...... how do you charge them then ??
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby matt dunn » Thu Jul 16, 2009 11:14 pm
jondee86 wrote:Sooooo...... how do you charge them then ??
Cheers... jondee86
We had to buy special battery chargers to do them.
They need to be removed from the vehicle and charged with a calcium charger at a much higher voltage than a normal car alternator puts out.
