wats required for a wof?
Postby 0EBUNY » Thu Oct 01, 2009 6:55 pm
ok got some questions for those of u who know a bit more about wofs.
my mums car went for a wof today and passed
:o
so one of the inner cv boots is completely in two pieces and was after the last wof
the tie rod ends boots are also split
theres no power steering fluid
theres oil pissing out the dizzy cap and its pooling on everthing underneeth
theres no oil left in the engine
i wondering about the boots being the main things they haven't even made any notes about any of it i thought at the least they would have a put a couple of notes saying it might pay to get that boot changed or top up the engine oil or even try and get some money out of her to fix stuff.
so are the boots required for the wof? or is it one of those dumb things that the joint underneath has to be busted before they pull u up on it?
im not vary impressed my mother knows absolutely nothing about cars and thinks im making a fuss about nothing (because i keep saying she needs to change the boots etc which i can get on staff discount and change) but she thinks if it needs doing they would have failed the wof or at least put a note they made a note about a tyre being close will need doing before next wof. but yea she dosent want to understand that doing the boot now will be cheaper then doing the whole joint later coz they would have told her.
new project
1998 toyota altezza :D where do i start plans go for miles
0EBUNY
Re: wats required for a wof?
Postby Paulio » Thu Oct 01, 2009 7:28 pm
pretty standard, if the boots are split for the cv and tie rod end then the joints are eventually going to shit themselves. potentially dangerous.
if the car came with power steering then it has to work.
not allowed any decent oil leaks, the dizzy o-ring is $&#$%. (but dont pull it out unless you can reset the timing)
the engine condition itself doesnt matter, so long as its not dangerous.
wof checks go by the bible called the virm vehicle inspection da-da-da-da
its online here: http://www.ltsa.govt.nz/certifiers/virm-in-service/
wof checks are full of it, to prove a point I took my car through 3 different wof stations here in the same week, all 3 picking up on different things, things that didnt matter, missing things that did matter etc.
meh
yees booy
Paulio
Postby Leon » Thu Oct 01, 2009 7:28 pm
0EBUNY wrote:o
Not a WOF fail unless it is dropping grease onto something like brake components.
That said ... 8O
Postby 0EBUNY » Thu Oct 01, 2009 8:00 pm
oh and the car pulls badly to one side.
new project
0EBUNY
Postby iOnic » Thu Oct 01, 2009 9:12 pm
Pretty much an instant fail if your car does any weird shit (pulling to either side = weird shit)
Postby Bling » Thu Oct 01, 2009 9:23 pm
Biggest problem I see here is that your mum drives on our roads in that piece of shit car.
No oil in the engine... why would the inspector care?? :lol: :lol:
Should ride a bike IMO
Postby DRFTIN » Fri Oct 02, 2009 12:16 pm
its not the wof guys job to make sure a car is well serviced...
DRFTIN
Postby THA SHZ » Fri Oct 02, 2009 2:54 pm
iOnic wrote:Pretty much an instant fail if your car does any weird sh*t (pulling to either side = weird sh*t)
where in the wof manual does it state that ?
THA SHZ
Postby iOnic » Fri Oct 02, 2009 3:01 pm
http://www.ltsa.govt.nz/certifiers/virm ... 9-v3a4.pdf
Page 5 #15 under Reasons for rejection
15. During operation:
a) the vehicle veers significantly to one side, or
b) the vehicle requires unreasonable force to steer, or
c) the steering is unreasonably stiff, rough or light.
Postby NZ_AE86 » Fri Oct 02, 2009 7:57 pm
Another reason that VTNZ should not be allowed to give a car a WOF.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby iOnic » Sat Oct 03, 2009 7:41 am
Why because they fail cars that could potentially drive off the road or into oncoming traffic? Yeah bad VTNZ! :roll:
Postby evil_si » Sat Oct 03, 2009 8:04 am
no as they usually dont drive them to be able to tell,
when was the last time you saw vtnz road test a car?
evil_si
Postby AceSniper » Sat Oct 03, 2009 8:38 am
:lol: and then when you have a plate lsd you have to spend 20min+ explaining what the clunking is
AceSniper
Postby iOnic » Sat Oct 03, 2009 7:19 pm
VTNZ have always taken mine for a drive around the building and they can tell if it's pulling either way while it's on the rollers.
Postby NZ_AE86 » Sat Oct 03, 2009 7:56 pm
iOnic wrote:Why because they fail cars that could potentially drive off the road or into oncoming traffic? Yeah bad VTNZ! :roll:
90% of WOF inspections done at VTNZ involve about 15 metres of test drive.
So they don't fail many cars that should fail for many reasons. :roll:
Current rides;
1986 Levin GT
NZ_AE86
Postby Jazza » Sat Oct 03, 2009 9:13 pm
Guy at VTNZ didnt fit in my bucket seats, so didnt even drive it. :lol:
1996 Curren - On Tardme
Jazza
Postby Bling » Sat Oct 03, 2009 9:45 pm
They make up on not test driving cars by failing them on trivial things, so they still fail as many cars as other places, just on stupid things :lol:
Postby 92mr2paddy » Sun Oct 04, 2009 12:22 pm
vtnz will fail you on anything they can possibly find,,,,vtnz = F%$Kwits,, why would you ever go there,, only reason i go there is to get rid of pinky/greeny,,, now days i dont even bother with that, simply get new plates :P:P:P
92mr2paddy
Postby NZ_AE86 » Sun Oct 04, 2009 6:02 pm
Even the guys that have done my WOF reviews (check us WOF guys to make sure we are doing a good job) say that VTNZ are the worst! If you want an easy WOF go to them, the staff at VTNZ stations are all failed or 'has been' mechanics. As they do not work on cars they end up being years behind on technology and fail a lot of things that are not faulty!
Current rides;
1986 Levin GT
NZ_AE86
Postby flygt4 » Sun Oct 04, 2009 6:18 pm
NZ_AE86 wrote:Even the guys that have done my WOF reviews (check us WOF guys to make sure we are doing a good job) say that VTNZ are the worst! If you want an easy WOF go to them, the staff at VTNZ stations are all failed or 'has been' mechanics. As they do not work on cars they end up being years behind on technology and fail a lot of things that are not faulty!
agree completely, although they do seem to feel obliged to fail you on something.
I usually disconnect the horn and take a reverse lamp etc out before I go for an inspection there, then they are happy when they find those easy faults and tend to ignore more major stuff that requires getting dirty to see. you can pop them back in in the carpark and walk inside for a pass mark so theres no need for a return trip :wink:
My ute I just bought had a very new VTNZ wof, and I picked up a couple of things that were of concern that had been missed, but the item they had failed it on first time round was superficial.
flygt4
