loudstealthGT-Four wrote:There is a ct20b turbo without the exhaust housing off a caldina gtt for sale on trade me and I was just wondering if it could be fitted to my ct26 in my gt4? And what is involved in that? Aaaand is that pretty much the same as bolting on a ct20b
Akane wrote:Chris, while on the same topic, I need the CT20b turbine inlet gasket, do you guys sell those at alltech?
Phothog wrote:the CTxx housing wont go into the CT26 Turbine housing without machining... but then you have a problem of the 4mm smaller turbine wheel.
Akane wrote:The holes for the bolts are bigger, gen 3 has bigger holes.
ionic what you want for yours?
OK Chris I'll see what I can do.
fivebob wrote:Phothog wrote:the CTxx housing wont go into the CT26 Turbine housing without machining... but then you have a problem of the 4mm smaller turbine wheel.
Will a Caldina housing and turbine fit a CT20b turbine housing... and will it work with the twin entry housing?
fivebob wrote:Bugger, because I've got a Blitz K1-380v upgraded GT-T turbo but the manifold is warped, was hoping it would fit into a CT20b exhaust housing
Akane wrote:Hey Chris, the gasket bolt holes just fits, needs to be persuaded but otherwise fine, cheers.
Phothog wrote:Akane wrote:Hey Chris, the gasket bolt holes just fits, needs to be persuaded but otherwise fine, cheers.
Sweet. Got it running yet? .... stupid question.
Chris.
