Ct26/ct20b
Ct26/ct20b
Postby loudstealthGT-Four » Tue Oct 06, 2009 6:53 pm
There is a ct20b turbo without the exhaust housing off a caldina gtt for sale on trade me and I was just wondering if it could be fitted to my ct26 in my gt4? And what is involved in that? Aaaand is that pretty much the same as bolting on a ct20b
loudstealthGT-Four
Re: Ct26/ct20b
Postby Boosted_162 » Tue Oct 06, 2009 7:09 pm
loudstealthGT-Four wrote:There is a ct20b turbo without the exhaust housing off a caldina gtt for sale on trade me and I was just wondering if it could be fitted to my ct26 in my gt4? And what is involved in that? Aaaand is that pretty much the same as bolting on a ct20b
Its not a CT20b no matter how much he says it is.
Read this - viewtopic.php?t=56255&highlight=ct15b
Fivebob knows what he is talking about.
Postby loudstealthGT-Four » Tue Oct 06, 2009 7:18 pm
Sweet as thanks for that
loudstealthGT-Four
Postby FLAWLES » Tue Oct 06, 2009 7:52 pm
thought they where ct15b's? with out clicking that link
FLAWLES
Postby MR2BOY23 » Tue Oct 06, 2009 8:11 pm
FLAWLES wrote:thought they where ct15b's? with out clicking that link
Yeah pretty much what it says in that thread
MR2BOY23
Postby Phothog » Tue Oct 06, 2009 9:44 pm
ah... as said above nope...
Different Turbine Wheel,
Different Bearing Housing,
the CTxx housing wont go into the CT26 Turbine housing without machining... but then you have a problem of the 4mm smaller turbine wheel.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby Akane » Tue Oct 06, 2009 10:27 pm
Chris, while on the same topic, I need the CT20b turbine inlet gasket, do you guys sell those at alltech?
Postby iOnic » Wed Oct 07, 2009 7:29 am
Akane wrote:Chris, while on the same topic, I need the CT20b turbine inlet gasket, do you guys sell those at alltech?
Are they the same as the CT26 gaskets? I think I may have one in my toolbox
Postby Phothog » Wed Oct 07, 2009 8:31 am
i dont have the inlet gasket by its self...
i only carry a kit (inlet, outlet (Ct26) Oil Feed/Drain & water Gaskets)
$22.00 +GST
Cheers,
Chris
Phothog
Postby Akane » Wed Oct 07, 2009 2:03 pm
The holes for the bolts are bigger, gen 3 has bigger holes.
ionic what you want for yours?
OK Chris I'll see what I can do.
Postby iOnic » Wed Oct 07, 2009 6:25 pm
I'll have a look for it tomorrow to make sure I still have it and PM you :)
Postby fivebob » Wed Oct 07, 2009 11:13 pm
Phothog wrote:the CTxx housing wont go into the CT26 Turbine housing without machining... but then you have a problem of the 4mm smaller turbine wheel.
Will a Caldina housing and turbine fit a CT20b turbine housing... and will it work with the twin entry housing?
Postby solitaire » Thu Oct 08, 2009 9:42 am
Akane wrote:The holes for the bolts are bigger, gen 3 has bigger holes.
Alltech will have them as i got all the right gaskets provided when they rebuild my ct20b
AE92, KZJ120, KDJ120
solitaire
Postby Phothog » Thu Oct 08, 2009 5:47 pm
Unfortunaly this one caught me out.
did an ST205 upgrade for a GT-T using the ST205 bearing housing, Comp Housing & Comp Wheel and a GT-T Turbine wheel....
only to find the internal mating flanges are different.
And
GT-T Turbine Wheel 48mm exducer
ST205 Turbine wheel 50mm exducer.
you could use the ST205 Core into a GT-T Turbine housing, as a bit of an upgrade...
bags not doing that one, would be an a$$ of a job with the turbine housing.
so the answer to your question is .... no.
Chris.
Phothog
Postby fivebob » Thu Oct 08, 2009 6:29 pm
Bugger, because I've got a Blitz K1-380v upgraded GT-T turbo but the manifold is warped, was hoping it would fit into a CT20b exhaust housing :cry:
Postby Akane » Thu Oct 08, 2009 7:59 pm
Hey Chris, the gasket bolt holes just fits, needs to be persuaded but otherwise fine, cheers.
Postby Phothog » Fri Oct 09, 2009 8:23 am
fivebob wrote:Bugger, because I've got a Blitz K1-380v upgraded GT-T turbo but the manifold is warped, was hoping it would fit into a CT20b exhaust housing :cry:
Just get another GT-T Manifold, they run the standard size turbine wheel,
(that was mesureing off a Blitz uprgaded one we had apart here).
Akane wrote:Hey Chris, the gasket bolt holes just fits, needs to be persuaded but otherwise fine, cheers.
Sweet. Got it running yet? .... stupid question.
Chris.
Phothog
Postby Akane » Fri Oct 09, 2009 3:28 pm
Chris.
Nope, by the time I got home last night it was getting dark, and it's raining today (although I have a garage). It's been like this everyday for the last 3 years, just no interest whatsoever. Will let you know when it lives again.
Postby RomanV » Fri Oct 09, 2009 3:44 pm
:lol:
