4AGE question
4AGE question
Postby sark.inc » Thu Nov 05, 2009 5:58 pm
Do the flywheels on the 4afe and 4age match up?
silvertop.
sark.inc
Postby bluemaumau » Thu Nov 05, 2009 5:58 pm
4afe 6 bolt
4age 8 bolt
Postby sark.inc » Thu Nov 05, 2009 6:00 pm
Well, now i need to buy a 4age flywheel :E
sark.inc
Postby Trls250s » Thu Nov 05, 2009 6:26 pm
sark.inc wrote:Well, now i need to buy a 4age flywheel :E
I have a spare 20v one i would be willing to part with. PM me
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby sark.inc » Thu Nov 05, 2009 7:51 pm
There is something else i know it.... damn it what am i forgetting?!?!?!
sark.inc
Postby shihad » Fri Nov 06, 2009 11:45 am
arnt early 4age bluetops 6 bolt
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby pc » Fri Nov 06, 2009 12:06 pm
shihad wrote:arnt early 4age bluetops 6 bolt
All 8 bolt.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
20v ticking qusetion
Postby headshotnz » Fri Nov 06, 2009 9:11 pm
So i got my levin on the road.
I dumbly enough forgot to check the oil (also have stuffed rings) went around some tight corners (some what fast... ), what i believe has happened is the very little remaining oil has moved to one side, resulting in my car left with a nice ticking sounds/ also car doesnt want to rev over 4-5ish rpm.
I also unplugged the VVT solinoid and it made no difference to the ticking, also the idle didnt change and the car felt no different to drive.
The ticking sounds like its coming from cylinder number 4 side, and up in the head region, apposed to the block.
Does any one know exactly what it is? first guess was siezed bottom end bearing.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Bling » Fri Nov 06, 2009 9:24 pm
So any oil in it?
Postby Mr Revhead » Fri Nov 06, 2009 9:35 pm
ticking? or knocking?
Postby MR2BOY23 » Fri Nov 06, 2009 9:57 pm
bottom end bearing wont make a knocking ticking noise as far as I know
MR2BOY23
Postby sergei » Fri Nov 06, 2009 10:30 pm
Essdub23 wrote:bottom end bearing wont make a knocking ticking noise as far as I know
It will, if there is enough play to touch valve/head.
Postby AE25 » Sun Nov 15, 2009 10:38 pm
i would be pulling oil filter off and chop it in half.. see if there's any bearing material in it.
don't suppose you have an oil pressure guage fitted? is it lower than normal at idle?
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby Truenotch » Sun Nov 15, 2009 11:02 pm
Sounds to me like you have run a big end bearing....
Truenotch
Postby sark.inc » Tue Nov 17, 2009 7:27 pm
Well just got a flywheel off endless spares, 75$ and it was machined! :D
sark.inc
Postby B_giB » Wed Nov 18, 2009 7:31 am
Good guys those Endless spares guys...
My cousin is the owner lol
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Flannelman » Wed Nov 18, 2009 5:27 pm
If there is enough play in the berring so the piston can touch the valves, no one will here it above the knocking of the conrod against the crank.
Mine gets rattly in the valve gear when its low on oil, especialy at idle. Change the oil and fill with 20-50
Flannelman
formerly known as Affroman
Postby sark.inc » Sat Nov 21, 2009 11:52 am
Does anyone have pictures of vacuum lines and such for the 4age silver?
I need to get some!!
sark.inc
