Interior stripping - Do/Don'ts
Postby TazzieDevil » Fri Oct 15, 2010 11:55 am
Hey, So I'm stripping back the interior of my celica.
Is there a list of things I can and can't take out, standards to make note of for bare metal, edges etc etc?
Get In, Sit Down, Shut Up & Hold On
TS Profile
It wasn't Me, it was the one armed Man!
TazzieDevil
Postby 2LTR Rona » Fri Oct 15, 2010 12:02 pm
Combination of "Common Sense" and "Sched A" :wink:
2002 Altezza, 1974 KE25
2LTR Rona
Postby DexGT » Fri Oct 15, 2010 6:02 pm
leave door trims by seats in (sched A), I'd recommend leaving at least one seat in (drivers one would be my call :wink: )
DexGT
Postby soopachargen » Fri Oct 15, 2010 6:58 pm
drivers seats are for quitters
When in doubt, down and out.
soopachargen
Postby Bling » Fri Oct 15, 2010 9:09 pm
Stripping it for what reason?
Postby UTERUS » Fri Oct 15, 2010 11:06 pm
BZG|Bling wrote:Stripping it for what reason?
Would you want to look at the interior of a celica?
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby Bling » Sat Oct 16, 2010 12:34 am
LOL :lol:
Postby TazzieDevil » Mon Oct 18, 2010 2:23 pm
LOL - thanks guys, Stripping to make the car less appealing to steal... That and it should be as light as possible, cause the car itself is damn heavy. I'm hoping to get back out to slipway photoworks series, if I can actually not work on the weekends for once.
TS Profile
TazzieDevil
Postby Leon » Mon Oct 18, 2010 2:27 pm
From the driver seat, pretend to be in a high speed roll over, and stretch your arms and legs out in all directions. If you encounter anything with your limbs, head, torso that due to interior trim being removed by you is now more pointy / bashy / stabby / cutty ... fix it or put the trim back again. That's how I've always approached the interior scrutineering.
I've found some astonishingly sharp bits in cars when people have ripped things out :cry:
Postby tim_blair » Tue Oct 19, 2010 10:58 pm
i love your work
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby Leon » Wed Oct 20, 2010 7:52 am
It's important to use the correct scientific terms in these cases :lol:
Postby TazzieDevil » Wed Oct 20, 2010 9:01 am
Leon wrote:From the driver seat, pretend to be in a high speed roll over, and stretch your arms and legs out in all directions.
Crap.... you said "Pretend" I knew I forgot something when I went about this.... LOL
In all seriousnesses though, I sat outside the mechanics today and stretched out my body parts, *te hehe* I couldn't reach anything "sharp" nothing that was going to cut or stab me, perhaps if it was a life / death situation, I could rub against a couple of parts and it might break some skin, but nothing leathal...
TS Profile
TazzieDevil
Postby stalker » Wed Oct 20, 2010 2:35 pm
For wof purposes...if you remove the back seats do you have to weld up the bolt holes for the seatbelts so it becomes a fulltime 2 seater as such?? Or is that an old wives tale?? :lol:
Or are you happy to be putting all the interior back in for each wof?
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby Santa'sBoostinSleigh » Wed Oct 20, 2010 2:55 pm
pretty sure thats a wives tale
take out seats AND seatbelts, then they cant complain
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby touge_ae101 » Wed Oct 20, 2010 3:08 pm
yep can confirm its an olds wifes tale!got my wof with no back seat. as long as you unbolt all of the seatbelts/fixtures associated with the rear seat then you are sweet. been driving it for a year like that with no problem. :D
touge_ae101
Postby stalker » Wed Oct 20, 2010 3:13 pm
Sweeeeeet!!
Might be removing the rears of mine now too lol
stalker
Postby TazzieDevil » Wed Oct 20, 2010 4:28 pm
When I got my WOF after removing back seats and belts, they asked if I wanted it changed to a 2 seater, or have it put on the cert as having removed the two seats... I didn't quite understand what the guy was getting at, but I just got it changed to being a 2 seater car.
If you have seats you need belts, if you have belts you need seats. So just remove both the belt and buckle, plus the seats and you're good to go.
TS Profile
TazzieDevil
Postby wde_bdy » Wed Oct 20, 2010 4:50 pm
Removing seatbelts will depend on the class and age of the vehicle, have a read through the seatbelt section of the WoF manual on the NZTA website.
Note LVV certification is not required where the only modification is the removal of seats and/or seatbelts. However, a class change and a new load rating may be required in some cases.
Passenger vehicles must have certain seatbelts fitted depending on the age of the vehicle and when it was first registered in NZ. My 1998 Mazda Demio for example is regularly WoF'ed with no rear seats but must retain the belts unless I do a class change. Some class changes will require permanent blocking of the seatbelt holes, particularly on newer cars. And remember, just because a WoF man passes it doesn't make it legal.
Callum
wde_bdy
Postby sergei » Wed Oct 20, 2010 4:55 pm
wde_bdy wrote:Removing seatbelts will depend on the class and age of the vehicle, have a read through the seatbelt section of the WoF manual on the NZTA website.
Callum
Incorrect.
I had compliance inspector call to LTSA and confirm that if seats AND seat belts are removed, it will pass warrant (without needing to do anything extra).
Remember this is not usual WOF man, but a compliance inspector (actually multiple of them).
Postby wde_bdy » Sat Oct 23, 2010 2:59 pm
It's not incorrect, that info is all from the WoF manual. As I said it will depend on the age and class of the car and when it was first registered here. There is no blanket rule, the advice on my was also checked with the LTSA/NZTA.
Callum
wde_bdy
