BZG|Bling wrote:Stripping it for what reason?
Leon wrote:From the driver seat, pretend to be in a high speed roll over, and stretch your arms and legs out in all directions.
Note LVV certification is not required where the only modification is the removal of seats and/or seatbelts. However, a class change and a new load rating may be required in some cases.
wde_bdy wrote:Removing seatbelts will depend on the class and age of the vehicle, have a read through the seatbelt section of the WoF manual on the NZTA website.Note LVV certification is not required where the only modification is the removal of seats and/or seatbelts. However, a class change and a new load rating may be required in some cases.
Passenger vehicles must have certain seatbelts fitted depending on the age of the vehicle and when it was first registered in NZ. My 1998 Mazda Demio for example is regularly WoF'ed with no rear seats but must retain the belts unless I do a class change. Some class changes will require permanent blocking of the seatbelt holes, particularly on newer cars. And remember, just because a WoF man passes it doesn't make it legal.
Callum
