3sgte in a ae101 levin
Postby KIPH8N » Fri Oct 15, 2010 4:59 pm
Has anyone done swaped a 4age with a 3sgte in a levin. Fwd gearbox. Need some info thanks. Mounts n etc
KIPH8N
Postby celica_xr9145 » Fri Oct 15, 2010 5:14 pm
Been asked loads of times.
Not a straight forward swap. Would need custom mounts for a start.
Would cost a sh!t load of cash!!!!
Also should probably be in the tech section :wink:
celica_xr9145
Postby dnalunchie » Fri Oct 15, 2010 8:11 pm
I don't want to discourage you but for the amount you will spend doing it you would be better off forging the 4age and turboing that, it has been proven time and again here that they can easily produce in excess of 400hp atw.
Current: 90 3sfe Corona
dnalunchie
Postby loudstealthGT-Four » Fri Oct 15, 2010 8:44 pm
dnalunchie wrote:I don't want to discourage you but for the amount you will spend doing it you would be better off forging the 4age and turboing that, it has been proven time and again here that they can easily produce in excess of 400hp atw.
+1
how much were you planning on spending? roughly?
loudstealthGT-Four
Postby Quirky » Fri Oct 15, 2010 8:57 pm
Ive seen an AE82 Hatch with a 3sgte front drive.
Seemed interesting, but it made 220kw at the wheels.
You can achieve the same power from a turbo 4a so probably not worth it.
Hello There
Quirky
Postby Bling » Fri Oct 15, 2010 9:13 pm
Moved to a more appropriate location...
Postby thegreatestben » Fri Oct 15, 2010 9:13 pm
For ~$8000 there is/was an EE90 that had been converted to full 4wd with ST205 motor. I'd say you'd spend that much just to make one FWD/useless
thegreatestben
Postby sergei » Fri Oct 15, 2010 9:50 pm
Quirky wrote:Ive seen an AE82 Hatch with a 3sgte front drive.
Well 220kW at FWD from 3SGTE is relatively easy to achieve. It would probably handle it all day long, on other hand the 4AGTE will be a hand grenade with that sort of power unless you spend twice as much as 3SGTE conversion will cost.
Postby matt dunn » Fri Oct 15, 2010 10:13 pm
sergei wrote:on other hand the 4AGTE will be a hand grenade with that sort of power unless you spend twice as much as 3SGTE conversion will cost.
Kw for Kw I would say a 3SGTE is much more of a hand grenade than a 4AGTE at the same hp.
220kw from a 4agte is not even a push.
Postby KinLoud » Sat Oct 16, 2010 12:33 am
Find a diesel corolla... Block bolt pattern same as 3sgte
Grab gearbox, mounts, driveshafts etc.
Only mount you would need to make is the one for the pulley end of the engine.
Ken
Postby iOnic » Sat Oct 16, 2010 10:05 am
matt dunn wrote:Kw for Kw I would say a 3SGTE is much more of a hand grenade than a 4AGTE at the same hp.
What makes you say that?
Postby shihad » Sat Oct 16, 2010 1:21 pm
wasnt there a thread fews years back that ended up comparing kws made verse money spent 4atges and 3sgte? from memory 4a seemed far better.i shall go for a dig.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby soopachargen » Sat Oct 16, 2010 1:28 pm
i believe the Jamaican ae101 guys use some st215 mount combination on the cambelt end
When in doubt, down and out.
soopachargen
Postby iOnic » Sat Oct 16, 2010 1:32 pm
Be interested in seeing that. I was making 210kw on stock fuel, stock ECU, stockish turbo (different compressor wheel), stock ignition on a 200,000km/20 year old 3SGTE and I beat on it all the time as well as used it as my daily...
Gonna have a hard time convincing me that it's cheaper to get a ~100kw engine to 220kw than it is to do the same to a 160-180kw engine.
Gonna have an even harder time convincing me that the one that started out with less power and no turbo is under less strain making that power than the one that had more power and a turbo from factory.
As for getting it in an AE chassis - why would it be any harder than putting it in an AW? Hasn't that been done multiple times now? It's effectively the same swap...
Postby soopachargen » Sat Oct 16, 2010 1:41 pm
soopachargen
Postby callum » Sat Oct 16, 2010 1:42 pm
I looked into putting a 3gse in my ae92 but couldn't find anyone wreaking a diesel one so gave up.
callum
Postby loudstealthGT-Four » Sat Oct 16, 2010 2:38 pm
that looks $&#$% sweet :D
loudstealthGT-Four
Re: 3sgte in a ae101 levin
Postby THA SHZ » Mon Oct 18, 2010 4:02 pm
KIPH8N wrote:Has anyone done swaped a 4age with a 3sgte in a levin. Fwd gearbox. Need some info thanks. Mounts n etc
done it in an ae92 , not as hard as people are making out , using mr2 lsd box out of sw is going to be the hardest bit of it trying to find one for decent money , and besides 3s is pretty good engine if you look after them , do what you wana do mate , some people on here are scared of the unknown 8)
Mounts i had a couple custom made as its in my race car , i have a solid one on cam belt side but you could get them made up easy enough , something that you could get evil si to do for you and hes out your way .
THA SHZ
Postby sergei » Mon Oct 18, 2010 4:11 pm
Another option for gearbox is E series out of SS3 (ST202) Celica (superstrut - it comes with LSD).
Postby Quirky » Mon Oct 18, 2010 4:27 pm
Or a camry box
Hello There
Quirky
