Fuel tanks
Fuel tanks
Postby tsoob » Wed Oct 27, 2010 9:04 am
After the long weekend away I worked out that the tank in my car is WAY too small. 28litres is all it takes.
I only got from papakura to tauramnaui and had to nana it the last 30k's cos my pressure was dropping around corners.
What options are there for a bigger tank in an ae92?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Mr Revhead » Wed Oct 27, 2010 9:16 am
What have you done to it to make it only take 28l?
Postby tsoob » Wed Oct 27, 2010 9:22 am
nothing, it only takes 28 l and its full. got me $&#$%...?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Mr Revhead » Wed Oct 27, 2010 9:25 am
iirc they only 35ish anyway....
Prob have to look at a fuel cell or custom tank then....
Postby touge_ae101 » Wed Oct 27, 2010 10:04 am
i would say that your fuel gauge is just on the piss.
ae92's have the same size tank as the rest of them so should be close to 45litres.
you would be suprised how much is in them even after the empty light comes on. did about 150kms with the empty light on and that wasn't even empty even after that! the guages are shocking on them so just need to play it by ear most of the time.
touge_ae101
Postby MAC_HATER » Wed Oct 27, 2010 10:25 am
just did a quick bit of research - apparently the AE92's Fuel-tank doesn't change per trim level and holds 13.2 Gallon - near as makes no difference 50L
so a few things could be:
as said fuel gauge\sender on the piss?
damage to tank? ie dented in? is this even possible?
or perhaps replaced due to damage with a much smaller tank?
are you able to try a different gauge and sender by any chance?
edit: - so basically what touge_ae101 said ;P
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby XSVWGN » Wed Oct 27, 2010 10:44 am
If yours turns out to be damaged and need another one i have one from my fxgt here. FREE to you ... just would need to organise courier. I would heaps out of my tank if i wasnt boooooosting around too hard haha!
Matt
2008 Kia rio - work car
XSVWGN
Postby sergei » Wed Oct 27, 2010 11:18 am
I am not sure how is this relevant, but my AE101 fuel tank is 50L. The most fuel I put in it was 49.6L - that was rolling in the petrol station without any fuel left (was student then :lol: ).
I doubt AE92 has 30L tank. It will be close to 40-45L.
Our Ist has 40L tank (max I put was 39.2L).
Postby MrOizo » Wed Oct 27, 2010 11:30 am
Could try taking the level sender out and checking it's range of motion. Could also try bending the floats arm to reset and reposition it. Check nothing is interfering with the travel of the arm.
Did you have the light on at all?
MrOizo
Toyspeed Legend
Postby metal_sean_head » Wed Oct 27, 2010 12:52 pm
Its definately closer to 40L.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby tsoob » Wed Oct 27, 2010 1:10 pm
its not the gauge. I already know its $&#$%, but it only fills up that far at the bowser, i know its low as the pressure drops and the car splutters.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby sergei » Wed Oct 27, 2010 1:12 pm
tsoob wrote:its not the gauge. I already know its $&#$%, but it only fills up that far at the bowser, i know its low as the pressure drops and the car splutters.
Checked the contents of the fuel tank? Perhaps some contraband there?
Postby Mr Revhead » Wed Oct 27, 2010 1:18 pm
I have heard of people doing track days moaning about fuel surge at 1/4 tank or so. Maybe you need to slow down for the corners a bit more :P
Where is your pressure reading taken from? Before or after surge tank?
Are you even running a surge tank?
Postby tsoob » Wed Oct 27, 2010 1:59 pm
Mr Revhead wrote:I have heard of people doing track days moaning about fuel surge at 1/4 tank or so. Maybe you need to slow down for the corners a bit more :P
no surge tank.
I dont have a gauge either, you can feel the pressure drop and the car splutters.
Doubtfull of contraband, i have had it out before when i did the pump.
I didnt build the car to go slow thru corners either :?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby touge_ae101 » Wed Oct 27, 2010 3:01 pm
once you get under 3/4 of tank on my ae101 the gauge will go from 1/4 full to right full under cornering. they have shocking baffles in them i never run under 3/4 of a tank at the track its just not worth it.
def check your guage i think its on the piss.
touge_ae101
breather
Postby fxgt race » Wed Oct 27, 2010 5:23 pm
Maybe check the breather tube isn't blocked, Could be trapping air in the tank when its filling if its blocked. Just a thought.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby QikStarlie » Wed Oct 27, 2010 6:55 pm
if has aftermarket pump in tank, check that its not mounted too far off the bottom, even if its only a bit higher up than factory will make quite a difference
QikStarlie
Postby matt dunn » Wed Oct 27, 2010 7:09 pm
QikStarlie wrote:if has aftermarket pump in tank, check that its not mounted too far off the bottom, even if its only a bit higher up than factory will make quite a difference
Yeah that would be my pick.
Either it is a non efi tank with and EFI pump in it and doesn't have the std surge pot in it,
or the pump setup is not right.
Run the car till it surges, then pull out the sender and see how much is left in it.
Postby tsoob » Thu Oct 28, 2010 11:31 am
ITS NOT THE GAUGE!!!! I DON'T HAVE A GAUGE!!!!!!!!!!! AT ALL!!!!!
what happens is the fuel gets down and the pressure drops and the car splutters.
I filled again last night, 29 litres, the car was really low as it was almost dying as i went into the gassy.
The pump may be installed wrong, but when i did it i remember putting it the way it was before. but ill check again
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby iOnic » Thu Oct 28, 2010 12:34 pm
Install a gauge (even temporarily) to check what level it's showing when the car splutters etc? Or check the level visually.
