tsoob wrote:its not the gauge. I already know its $&#$%, but it only fills up that far at the bowser, i know its low as the pressure drops and the car splutters.
Mr Revhead wrote:I have heard of people doing track days moaning about fuel surge at 1/4 tank or so. Maybe you need to slow down for the corners a bit more
Where is your pressure reading taken from? Before or after surge tank?
Are you even running a surge tank?
QikStarlie wrote:if has aftermarket pump in tank, check that its not mounted too far off the bottom, even if its only a bit higher up than factory will make quite a difference
Users browsing this forum: No registered users and 32 guests
