Oil Pressure Sender thread change?
Postby XSVWGN » Tue Dec 28, 2010 1:07 pm
hey i have just got some new gauges and my oil pressure sender doesnt fit into my block. The Thread is still the same but the one for my gauge is bigger then the standard one.
Do i have to buy a replacemtn sender with the right size or do can i jst remove the thread off the sender and replace it with one that fits?
that make sence?
Matt
2008 Kia rio - work car
XSVWGN
Postby Burning Angel » Tue Dec 28, 2010 1:16 pm
i think you'll find that your block has 1/8bspt which is 26Threads per inch whereas the sender is 1/8npt which is 27 threads per inch and wont screw in
you cant take the thread off the sender and as far as im aware you cant get npt to bspt adaptors. you could run a bspt die over the thread on the sender to change it, or conversly run a npt tap into the block(although i wouldnt reccomend that)
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby XSVWGN » Tue Dec 28, 2010 5:57 pm
so reccomendation is to changen the thread on the sender then? Who would i go see to get this done? Im sure headmasters or someone similar would be the go
Matt
XSVWGN
Postby loudstealthGT-Four » Tue Dec 28, 2010 6:26 pm
Any engineer should be able to rethread it for you
loudstealthGT-Four
Postby FLAWLES » Tue Dec 28, 2010 9:04 pm
i wouldnt re thread it
it will be crap/weak metal and will just fold under the pressure of the die
just use one of these and be done with it
FLAWLES
Postby matt dunn » Tue Dec 28, 2010 9:09 pm
I wouldn't put it into the block at all.
I would make a flixible line from the block where the sender should be to the sender and mount it on th body.
Postby FLAWLES » Tue Dec 28, 2010 9:12 pm
also do that
have done that in the past with bradied line running out of the oil pressure sender hole and mounted it on the strut tower
also re my other post
those mounting blocks have a tendency on leaking
FLAWLES
Postby XSVWGN » Tue Dec 28, 2010 11:03 pm
ok so get Hydralink or similar to make up a short line then and mount it on the chassis how exactly?
Matt
XSVWGN
Postby Bazda » Wed Dec 29, 2010 11:42 pm
You can run a NPT tap through. I've done it of 5 engines already and it works fine with no leaks.
I haven't had a sender break off the block either. The only time they break off is if you use those brass fittings to make a T to bring the oil feed line off that port as well.
Postby evil_si » Thu Dec 30, 2010 8:23 am
I have also re tapped the block many times to suit npt fittings,
Were are you taking oil feed for turbo from?
Same place?
Ive also used bsp steel T pieces in the past and re tapped one side to suit npt
When re tapping the block I put plenty of grease on the tap so the filings stick to it, rather than staying in the block,
The thread change is so small there isn't much in the way of filings or swarf anyway
evil_si
Postby AE86fan » Thu Dec 30, 2010 3:05 pm
If you wanted to save some money, I have used a standard toyota rubber brake hose in the past which screws into the block perfect and then you can remote fit your sender from there, not as bling as a made one but does the same thing :D
1984 NZ AE86
AE86fan
Postby XSVWGN » Thu Dec 30, 2010 9:56 pm
evil_si wrote:I have also re tapped the block many times to suit npt fittings,
Same place?
Oil feed for turbo comes from relocator block. Ok well maybe i will just retap the block then... not a huge issue really
Matt
XSVWGN
