Whats the tidiest way to cut a side skirt?
Postby siren676 » Fri Jan 28, 2011 1:13 am
I have got some side skirts that i want to fit to my 5dr starlet but they require having a small piece cut off to allow the rear doors to open.
I dont want to use a hacksaw or jigsaw as it would be messy.
I work at a hobby shop and can get a hot wire cutter which is usually used for cutting foam. Would this work?
Any other ideas on ways to cut it?
They will eventually end up like this.
siren676
Postby DeeCee » Fri Jan 28, 2011 6:38 am
dremal tool with reinforced cutting wheel disc is generally what i use when cutting fg or plastic. sometimes hacksaw and even a angle grinder with cutting disc on it work as well.
GT Four Adovansu
DeeCee
Postby evil_si » Fri Jan 28, 2011 7:23 am
plastic or fibreglass?
evil_si
Postby iOnic » Fri Jan 28, 2011 7:59 am
Just use a dremel/angle grinder/hacksaw then file/sand the cut down so it's smooth.
Postby tsoob » Fri Jan 28, 2011 10:34 am
iOnic wrote:Just use a dremel/angle grinder/hacksaw then file/sand the cut down so it's smooth.
this
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby siren676 » Fri Jan 28, 2011 11:39 am
Sweet ill try to find a dremel.
Anyone got one i can buy/borrow/steal/rent? :lol:
siren676
Postby iOnic » Fri Jan 28, 2011 12:01 pm
A rotary tool is only like $20-30 from a hardware shop. Handy for other things too.
Postby siren676 » Fri Jan 28, 2011 12:06 pm
Not bad, ill stop by mitre 10 mega on my lunch break and see if they have any.
2nd question, what would be the best way to mount the skirts?
siren676
Postby Dell'Orto » Fri Jan 28, 2011 12:10 pm
Tek screws and No More Nails
take photos if you do
Postby Boost_4_Life » Fri Jan 28, 2011 12:35 pm
rivets and sikaflex.
The rally beast
The rally beast again!
Boost_4_Life
Postby sik_gt_starly » Fri Jan 28, 2011 12:39 pm
cable ties :P
sik_gt_starly
Postby B_giB » Fri Jan 28, 2011 2:58 pm
Just make them out of household guttering
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby h8wrxs » Fri Jan 28, 2011 3:45 pm
sik_gt_starly wrote:cable ties :P
+1 lol
h8wrxs
Postby siren676 » Fri Jan 28, 2011 11:48 pm
I bought a mini dremel type kit which comes with some cutting disks and about 40 other attachments.
The guy at mitre 10 suggested that i use araldyte(my spelling sucks) to hold the skirts on.
I'm a little worried about using screws or pop rivets as I'm not sure whether it would cause rust or not
siren676
Postby cat007 » Sat Jan 29, 2011 12:22 am
O/T but how much was the dremil kit?
Postby h8wrxs » Sat Jan 29, 2011 1:03 am
ive seen cheap dremel kits at bunnings, think ive seen them for around $40
h8wrxs
Postby siren676 » Sat Jan 29, 2011 1:16 am
cat007 wrote:O/T but how much was the dremil kit?
From memory it was <$40. Its called a "Mini hobby kit & engraver".
Ill chuck a pic up tomorrow if my sister hasn't nicked the camera :lol:
siren676
Postby holden_fan2005 » Sat Jan 29, 2011 1:23 am
I'm planning to rivet/use stainless screws on each end where the kit tucks into the guard and some wurth bond glue stuff. Will see how it works out. Double sided tape has been suggested too.
holden_fan2005
Postby siren676 » Sat Jan 29, 2011 1:37 am
8O Double sided tape? would have to be really good stuff to hold on a side skirt.
Mine has some removable bungs that i think i can screw into (hole in skirt lines up to it) im thinking to use screws there and pop rivets on the underside as well as some sort of adhesive to hold the side bit.
Hopefully that will be enough.
siren676
Postby Bling » Sat Jan 29, 2011 8:49 am
Holdenfan has the right idea
The screws are what hold it on, the double sided tape just holds the length of the skirt on. What do you think is used to hold plastic strips on cars from the factory :wink:
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
