I dont want to use a hacksaw or jigsaw as it would be messy.
I work at a hobby shop and can get a hot wire cutter which is usually used for cutting foam. Would this work?
Any other ideas on ways to cut it?
They will eventually end up like this.
iOnic wrote:Just use a dremel/angle grinder/hacksaw then file/sand the cut down so it's smooth.
sik_gt_starly wrote:cable ties
cat007 wrote:O/T but how much was the dremil kit?
