BOV not working
BOV not working
Postby bluemaumau » Wed Feb 23, 2011 10:18 am
Trust type R BOV
the bov has never worked, even up to 20psi
it has two ports
the bottom one is left open
the top has vaccum from the inlet manifold (direct, no t's)
will get a pic up soon.
i can press the valve with my thumb so its not seized.
i brought this brand new ~3years ago.
Postby strx7 » Wed Feb 23, 2011 11:03 am
get a vacuum pump attach it to where you currently have vacuum hose attached, pply vacuum and see if it opens, if it doesn't try it on the other hose nipple. Is it an adjustable BOV? try adjusting it so it requires less force to open. Is you vacuum source definitly after the throttle body?
Postby tsoob » Wed Feb 23, 2011 11:39 am
buy a samson from me :D
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby bluemaumau » Wed Feb 23, 2011 1:30 pm
yup i tapped fittings for everything into the inlet, so yup after the t/b
vaccum pump, never heard of it? would engine reconditioners have that sorta thing?
yup adjusting, on softest setting atm
Postby Stu- » Wed Feb 23, 2011 1:45 pm
You've got a deisel 4age don't you?! :D
The line that your using is definitely vac line and not collapsing on itself restricting it?
Project Thread
Stu-
Postby strx7 » Wed Feb 23, 2011 2:23 pm
bluemaumau wrote:y
used to testing vacuum advance units on distributors, most garage/workshop should have one.
Postby bluemaumau » Wed Feb 23, 2011 4:43 pm
Stu- wrote:You've got a deisel 4age don't you?! :D
sounds like it :lol:
yea bought it as vac line, although that could be a possiblity, will check
