Random Questions (Turbo's & General Maintainance)
Postby BZG Wagon » Sat Mar 26, 2011 5:18 pm
In the middle of an oil change on my GTT speed-sleigh-of-doom and wondering....
1) Carb Cleaner + Turbo = Good Idea? I see there's a tiny bit of grey dust like carbon on the turbo fins; would a couple of squirts loosen this and dissolve into the engine and prevent further build ups?
2) How much oil in the turbo is too much? When I pulled the intake pipe off the turbo there was maybe 1/4 - 1/2 a teaspoon sitting in there + a very thin layer of caked oil spread through most of the intake pipe. Also a little bit in what I think is the PCV breather. Can't say I'm overly worried about it - there didn't seem to be any play in the turbo. Is it something I should keep an eye on? Should I be a bit easier on the ol' turbo?
3) What's the best way to clean intake pipes & intercooler? I hear carb cleaner is bad for rubbers & plastics, which is how I traditionally cleaned these things.
4) Is carb cleaner down the throttle a bad idea? A mechanic taught me this trick and I must say it works wonders to throttle response etc. Another mechanic (who I have a lot of respect for) said it was a stupid idea, and he's seen a few vapored locked engines as a result of this technique, not to mention potential damage to sensors (he was pretty fired up about it so I dropped the subject). I can't say I use a hell of a lot of spray and I normally try to run a tiny bit through there while the engines running (I haven't tried this on the dina though).
5) Are Toyota Oil + Air Filters worth it? I used a Repco filter for the first two changes, and I must say the Toyota filters are miles better; they're bigger, smaller jackets, look like the filter more and generally keep the oil looking 'golden' for the entire 5,000kms. The air filter I've never been overly sure about; but at $70 for the combo they're getting a bit pricey for my liking. Any better (or identical yet unbranded) alternatives?
Interested in everyone’s opinions & experiences.
Ta.
BZG Wagon
Postby evil_si » Sat Mar 26, 2011 5:31 pm
Vapour locked engines... :roll: right, i wouldnt have much respect for anyone that said that shiz,
Carb cleaner and brake clean disppear pretty damn quick on contact with air, if you start the engine to soon after spraying to much of it, it may rev up while burning the vapour,
evil_si
Postby tsoob » Sat Mar 26, 2011 7:36 pm
i just use fram oil filters and change them lots.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bling » Sat Mar 26, 2011 7:45 pm
If there is one thing i've found, everyone is an expert on oil/filters and recommend different ones each time :lol:
Not a big cost to go genuine filters. Not sure what i'm even running at the moment, I think its ryco or something. Have used Fram, Genuine, Repco etc.
Postby Akane » Sat Mar 26, 2011 8:02 pm
2) any pooling of oil is bad, a heathy turbo should be just a tiny film of grease if any.
Postby Boosted_162 » Sat Mar 26, 2011 8:48 pm
Kinda related, but my RB26 had some shit filter put on it when i bought it, used to be pretty slow to build up oil pressure. Got a genuine one on now and difference in building up pressure is crazy, same weight oil etc.
Postby cozmoid » Sat Mar 26, 2011 9:05 pm
You can buy AFm cleaner that is very safe for all your sensors, tubes, turbo etc. No risk no worries. Also I have done a wee bit of experimenting with genuine thermostats and filters and they are far superior. If it's a hack or whatever then use anything but if you love you car and wanna keep it then go genuine. Just my experience. Also my fc3s used to get a little oil blow back through the breather into the intake tube which could get a little oily. I just got a oil catch can and closed off the intake hole. Fixed! Mid mileage engines will blow back a little oil. A cheap test is clean everything and use a pump bottle for a oil catch can so you can test whether this is the actual source of the oil.
Good luck, sounds like a sweet ride
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby Stu- » Sun Mar 27, 2011 8:45 am
BZG|Bling wrote:If there is one thing i've found, everyone is an expert on oil/filters and recommend different ones each time :lol:
Agree. However cut a few different ones appart and you can see the difference in the amount of filtering material inside. Genuine are worth it in my opinion.
Project Thread
Stu-
Postby YeMs » Sun Mar 27, 2011 10:31 am
AND not very expencive either. the air filters get pretty pricey though... specially when you price a TRD option for an altezza.. $250 thanx =S. Best thing is to find a friend who works there and get parts at cost ;).
I have cut a few filters open in my time and FRAM are definately my next option. the ryco filters are pretty questionable imho.
Your local Hybrid Elite tech
YeMs
Postby evil_si » Sun Mar 27, 2011 12:23 pm
YeMs wrote:[
Spotted a fram vs wix display fiters the other day, the wix had twice as much filter media inside than the fram
evil_si
Postby YeMs » Sun Mar 27, 2011 1:35 pm
evil_si wrote:
YeMs wrote:[
oh tru? interesting.. do you think that there is such a thing as 'too much' filter? causing too much restriction and not allowing enough pressure past..?
YeMs
Re: Random Questions (Turbo's & General Maintainance)
Postby MAGN1T » Sun Mar 27, 2011 9:44 pm
BZG Wagon wrote: 2) How much oil in the turbo is too much? When I pulled the intake pipe off the turbo there was maybe 1/4 - 1/2 a teaspoon sitting in there + a very thin layer of caked oil spread through most of the intake pipe. Also a little bit in what I think is the PCV breather. Can't say I'm overly worried about it - there didn't seem to be any play in the turbo. Is it something I should keep an eye on? Should I be a bit easier on the ol' turbo?
Oil in the intake pipes comes from the breather due to too much blowby in the motor. Common in high milage turbo motors (worn rings) and common in modded turbo motors (broken ringlands due to detonation).
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Dell'Orto » Sun Mar 27, 2011 9:50 pm
evil_si wrote:
YeMs wrote:[
Will take a pxt of the filters we cut open at work...I wouldnt use a Fram filter on a tractor :?
Postby BZG Wagon » Sun Apr 03, 2011 5:49 pm
Thanks for the tips guys. The motors just a fraction off 150kms so it sounds like the oil in the intake is normal. If it gets worse I'll look at a catch.
I'll also stick with the TGP filters. I was hoping someone would say 'oh yea they're just black ryco filters' or something. :P
One last question; I've heard several rumours that engine flush is just bottled kerosine and nothing else. Anyone know if this is true - given 1L of kerosene costs $7, vs. a 250ml bottle of engine flush for $15.
As a 'test' I flushed kerosene through my lawnmowers oil before I changed the oil in it. Seemed to work very, very effectively.
BZG Wagon
Postby Dell'Orto » Sun Apr 03, 2011 6:47 pm
Pretty much, might have some white spirits or some other solvent in it. Not such a fan of engine flushes personally.
Postby BZG Wagon » Mon Apr 04, 2011 1:22 pm
Dell'Orto wrote:Not such a fan of engine flushes personally.
Why's that?
BZG Wagon
Postby sergei » Mon Apr 04, 2011 2:23 pm
Engine flush is kerosene.
It messes with seals, and loosens sludge (if engine is sludged) to a point where it blocks strainer.
Postby Mr Revhead » Mon Apr 04, 2011 5:57 pm
evil_si wrote:
YeMs wrote:[
I've seen Fram vs Donaldson and yeah, the fram was a bit lacking...
Postby sark.inc » Thu Apr 07, 2011 8:01 pm
Most good filters will filter around 30ish microns, so i really can't see a toyota filter vs a ryco or (insert brand here) filter making the oil look more golden. I would say it comes down to the quality of oil you used.
btw "clean" oil is not normally good as imo it means the oil is not doing part of it's job.
p.s i would never use a FRAM btw.
sark.inc
Postby phoenix » Thu Apr 07, 2011 8:45 pm
sergei wrote:Engine flush is kerosene.
Yep it's not uncommon for an engine with moderate kms to sprout leaks after using engine flush.
phoenix
