Rear suspension issue? - Sorted
Postby siren676 » Sat May 28, 2011 12:03 am
I was on my way home from work tonight and the rear of the car felt like it was floating left to right around corners and off camber straights. :?
Could a panhard rod bush be gone?
siren676
Postby Brawler » Sat May 28, 2011 9:44 am
drifting?
zing! Sig got nuked. Sorry bout that.
Brawler
Re: Rear suspension issue?
Postby touge_ae101 » Sat May 28, 2011 10:34 am
siren676 wrote:Could a panhard rod bush be gone?
Sure it could be that would make sense but you are Probably more qualified to find that out by taking a look than us trying to guess from behind a screen..
Jack the rear of the car up (not by the axle) and give everything a good push/pull and track it down. They are real simple with a solid rear axle and trailing arms I think so only about 5-6 bushes that could have worn out.
Or it could of just been the wind (or a seagull farting) pushing your smaller than average car around! :p
touge_ae101
Postby siren676 » Sat May 28, 2011 11:12 am
Brawler wrote:drifting?
How'd you know that caused it?
It was still doing it on the way to work this morning so somethings not right.
Ill jack the car up after work and check over all the bushes.
siren676
Postby Elmendorf » Sat May 28, 2011 5:30 pm
Wow PMS or just not getting any :?: :lol:
More than likely one of the bushes. Easiest thing is to replace the lot with Nolathane ones if you still running factory bushes.
Elmendorf
Postby amdeman » Sat May 28, 2011 6:58 pm
Harlet wrote:More than likely one of the bushes. Easiest thing is to replace the lot with Nolathane ones if you still running factory bushes.
Where's the place to find those, also what's involved in doing the job?
Cheers.
amdeman
Postby siren676 » Sat May 28, 2011 7:05 pm
Autolign is probably the best place to get them from.
I think they have to be pushed out with a press.
Jacked the car up after work and all the bushes were alright when trying to move them with a pry bar. I think it must have been the loose gravel last night causing it to feel weird.
siren676
Postby amdeman » Sat May 28, 2011 8:15 pm
siren676 wrote:Autolign is probably the best place to get them from.
Cheers for that!
amdeman
Postby Simon K » Sun May 29, 2011 2:12 pm
Has a rear shock failed? When one went on the back of the Carib, it felt very weird to drive.
Simon K
TS Wannabe
Postby siren676 » Sun May 29, 2011 6:52 pm
Turns out the left rear tyre was 15psi less than the others and I was driving on loose metal.
Car was perfectly fine as i just pumped the tyre back up and did a track day at hampton without any issues.
siren676
Postby tsoob » Mon May 30, 2011 10:30 am
Cheers.
get them from me ;)
Will discount the price for toyspeed members
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby amdeman » Mon May 30, 2011 2:12 pm
Cheers.
get them from me ;)
Thank you! Again!
Looking forward to being a happy customer, yet again.
Shall be in contact pronto.
amdeman
Users browsing this forum: Bing [Bot] and 29 guests
