As such I dont want to have to spend $$$ on a controller, so was hoping to make one from kitset parts.
I had originally thought about trying to make on which you could set frequency and duration of the spray (i.e 2 sec spray every 5 min)
I have found time delay relays, or timer kits that would be suitable for the first parameter (i.e how often to switch), but I am stuck on how to make it so that the length of time it trigger for is adjustable.
So...any links to tips to help achieve it?
Or do I just run a couple of potentiometers in series?
Really dont want to have to manually switch the water sprayer
