Intercooler water sprayer - controller build option?
Postby no_8wire » Thu Feb 23, 2012 10:00 am
Looking at making a cheap water sprayer system for my pug.
As such I dont want to have to spend $$$ on a controller, so was hoping to make one from kitset parts.
I had originally thought about trying to make on which you could set frequency and duration of the spray (i.e 2 sec spray every 5 min)
I have found time delay relays, or timer kits that would be suitable for the first parameter (i.e how often to switch), but I am stuck on how to make it so that the length of time it trigger for is adjustable.
So...any links to tips to help achieve it?
Or do I just run a couple of potentiometers in series?
Really dont want to have to manually switch the water sprayer :lol:
no_8wire
Postby Vertigo » Thu Feb 23, 2012 10:08 am
id start with a switch, then wire in a timer after its all going.
TVIS just kicked in, yo!
Vertigo
Postby Mr Ree » Thu Feb 23, 2012 10:08 am
Wouldnt dick smith sell a kit to do what you want?
Personally, Im just going to use the rear window sprayer line and manually activate it while going down the straights :)
wak thud gush!
Mr Ree
Postby Mr Revhead » Thu Feb 23, 2012 10:37 am
Jaycar more likely. Dick Smith are now just an appliance store. Can't even get components anymore
Postby MrOizo » Thu Feb 23, 2012 11:00 am
Mr Revhead wrote:Jaycar more likely. Dick Smith are now just an appliance store. Can't even get components anymore
Smaller towns arent too bad. They have the up-rights with components but arent replacing them :(
There used to be a intercooler sprayer kit but cant find it. Maybe Silicon Chip have it in their catalogue still.
MrOizo
Toyspeed Legend
Postby MrOizo » Thu Feb 23, 2012 11:02 am
MrOizo
Toyspeed Legend
Postby no_8wire » Thu Feb 23, 2012 11:05 am
You have to buy the article though...I think autospeed used to do a kit that is discontinued now...
Trying to find a repeat cycle delay as that will allow you to set the spray time as well as down time in the one unit.
no_8wire
Postby no_8wire » Thu Feb 23, 2012 12:21 pm
I think I have found what I need...a repeat cycle timer.
no_8wire
Postby sergei » Thu Feb 23, 2012 1:07 pm
no_8wire wrote:I think I have found what I need...a repeat cycle timer.
What ECU are you using? Most aftermarket ECU have a facility for intercooler sprayer (or you can program an output).
You can build a simple 555 timer that will do the job...
Postby no_8wire » Thu Feb 23, 2012 1:23 pm
I dont have an ecu... 8O
Mechanical injection all the way!!!
:lol:
So the trigger/switching along with frequency and duration will need to be covered by the controller.
no_8wire
Postby Mr Revhead » Thu Feb 23, 2012 1:38 pm
Is it for a track car? Just make it a.simple on off and run it all the time on track.
Ignore if its a shits and giggles project
Postby no_8wire » Thu Feb 23, 2012 1:45 pm
No, its for my daily...but planing on winding up the boost, and diesel fuelling, and as such wanting to improve the cooling of the intercooler which is a top mount. (Other option was a bonnet scoop)
Car is a pug 405... 1.9l of turbo diesel fury!
:lol:
(But fuelling is so adjustable on this thing it is fantastic! Max fuel, On boost addition, how much boost to trigger the on boost fuelling, such a change to modifying petrol ECU controlled cars)
no_8wire
Postby Mr Ree » Thu Feb 23, 2012 2:53 pm
What type/size jets are you thinking about using for the sprayer pal?
I bought some 0.3mm misters but am yet to see how they perform. Once I have bought my GoPro, I plan on mounting it on the nose of the car and facing it to the FMIC so I can see how the water is atomising at speed, and where its ending up due to the turbulence.
wak thud gush!
Mr Ree
Postby no_8wire » Thu Feb 23, 2012 2:57 pm
um....what ever size the jets are on the stock window sprayers...
I said this was cheap! :lol:
Peugeot sprayers are on a bar located on the wiper arm. Each bar has 3 sprayers. So I plan to fit one bar to each side of the intercooler and aim it inward toward the other side.
So it will have 6 sprayers onto the cooler.
Unsure of nozzle size at this point, and my ruler only does 1mm increments!
:lol:
no_8wire
Postby Mr Ree » Thu Feb 23, 2012 3:07 pm
You can buy extremely cheap misters from the gardening section of bummings :)
wak thud gush!
Mr Ree
Postby no_8wire » Thu Feb 23, 2012 3:24 pm
Mr Ree wrote:You can buy extremely cheap misters from the gardening section of bummings :)
bummings?
8O
Not sure if Im too keen on visiting there tbh...
Is that Bunnings gay cousin or something?
:o
no_8wire
Postby strx7 » Thu Feb 23, 2012 3:27 pm
if it is a diesel, then fork out some $$ for a good 200+psi pump and start spraying a blend of Water & Meths down its throat. it's like NOS to a deisel
The water acts as a cooler, the meths/methanol acts as fuel for the additional intake charge, and you will thoroughly enjoy having extra power at the flick of a switch
depending on how much boost you push, 3GPH or 4GPH max would be enough flow for it, and run 40% meths/60% water
www.coolingmist.com is your friend
Postby whynot » Thu Feb 23, 2012 3:28 pm
So what do you plan to use as a trigger to start this sprayer? Tps, map, intercooler temp? Sounds like you need a voltage switch and some form of a pulse width controller or a multi purpose timer
whynot
Postby sergei » Thu Feb 23, 2012 3:39 pm
whynot wrote:So what do you plan to use as a trigger to start this sprayer? Tps, map, intercooler temp? Sounds like you need a voltage switch and some form of a pulse width controller or a multi purpose timer
Simples solution is a throttle microswitch (same type as used on basic NOS).
Postby whynot » Thu Feb 23, 2012 3:50 pm
True. A micro switch and a valve to control water flow, cant get much cheaper than that
whynot
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
