Radiator issues... again
Postby FST4RD » Sat Mar 30, 2013 4:03 pm
Hey all, got home last night in the Alto and seems the radiator is bust another leak. Got a new thermostat and radiator hoses coming, thought I might as well replace them
With regards to the radiator I obviously have a few options, source a second hand radiator, however probably will have the same issue. Source a new one, get it recored, get something aftermarket and fit it.
What's going to be the best option? I use the car to do long trips to Dunedin, Westcoast etc quite regularly, so I'm wondering whether the 1 odd cm thick core is up to the task?
If I take the current radiator into a radiator place, can they fit a thicker core onto the end tanks?
Do they have generic radiators that have multiple mounting points I can use
If the cores buggered will the end tanks start splitting
Am I being paranoid?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby 85AW20v » Sat Mar 30, 2013 9:44 pm
Irontite......
See ya
Simon
85 MR2 20v
85AW20v
Postby FST4RD » Sat Mar 30, 2013 9:46 pm
I had fixed the first hole with kneed it and that stop leak stuff, but it's leaking again in another place.
FST4RD
Postby Lloyd » Sat Mar 30, 2013 10:01 pm
Take the radiator out, take it to a radiator shop and get a profession opinion on it. If there core isn't stuffed and they can just throw a new tank on it then it may be the best option.
Failing that, get in touch with A1 Radiators (http://www.a1radiators.net.nz) and see what a new one is worth. They're usually fairly reasonably priced, are in Christchurch and list all their products with dimensions and pictures on the website so you can see if they have a listing on yours too.
